4.86 gears with a small block #1616608
05/05/14 05:24 PM
05/05/14 05:24 PM
CA.
RAY1969CARS Offline OP
CA.
Whats your combos ??? Cam, tires motor and what are you shifting at? And out the gate ?
Re: 4.86 gears with a small block [Re: RAY1969CARS] #1616609
05/05/14 06:20 PM
05/05/14 06:20 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
4.88 dana gear, 14-32 M/T slick
stock 1.76 gearset powerglide
pump gas 408, 750 holly, app 11.4 comp
shift@6400
convertor stall 5100
550 solid lift cam with app 275CFM Edelbrock heads
2850 pound duster
6.30-6.40@106mph 1/8 mile
best last year 10.06@130mph 1/4 mile
Engine is out of guts at 1000ft due to small cam, low cfm numbers, and small carb. Stepping up to better combo this year.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 4.86 gears with a small block [Re: pittsburghracer] #1616610
05/05/14 07:18 PM
05/05/14 07:18 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
4.88 dana, 14-32 tire, 398 ci, 650 roller cam, w2 heads 727 trans, shift at 7400..9.70s...bye the way this motor is for sale...
Re: 4.86 gears with a small block [Re: RAY1969CARS] #1616611
05/05/14 07:52 PM
05/05/14 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was running a 4.88, shifting at 8000, trapping at
8200, 14X31 turning 136 mph... I run a 4.56 now
running 152mph
Re: 4.86 gears with a small block [Re: MR_P_BODY] #1616612
05/05/14 09:52 PM
05/05/14 09:52 PM
CA.
CA.
Is a 30 inch tire to small 12 1 w5 with 720 roller
Re: 4.86 gears with a small block [Re: RAY1969CARS] #1616613
05/05/14 10:03 PM
05/05/14 10:03 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I ran a 5.13 in my challenger with 16x32 goodyears
Re: 4.86 gears with a small block [Re: RAY1969CARS] #1616614
05/05/14 10:27 PM
05/05/14 10:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With a 4.86 gear... depends on how quick you go...
but I'd run it
Re: 4.86 gears with a small block [Re: MR_P_BODY] #1616615
05/06/14 02:07 AM
05/06/14 02:07 AM
CA.
CA.
Hopping for low low tens maybe 9.90
Re: 4.86 gears with a small block [Re: RAY1969CARS] #1616616
05/06/14 02:33 AM
05/06/14 02:33 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Variable will be your converter. However, typically a small block with a 4.86 goin 9.90 is gonna be about 131-134 mph with a 32 inch tall tire at around 7200 give or take 100 rpm. Shorten the tire and obviously the RPM's increase
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: 4.86 gears with a small block [Re: pittsburghracer] #1616617
05/06/14 02:23 PM
05/06/14 02:23 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Engine is out of guts at 1000ft due to DANG TRANS WONT SHIFT AGAIN
Fixed
Re: 4.86 gears with a small block [Re: HotRodDave] #1616618
05/06/14 02:32 PM
05/06/14 02:32 PM
PA.
"Little"John
"Little"John
PA.
Fixed
I know its (powerglide) giving up some ET but they sure are great for us bracket racers.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 4.86 gears with a small block [Re: HotRodDave] #1616619
05/06/14 02:44 PM
05/06/14 02:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Fixed
Its still one to one in high gear
Re: 4.86 gears with a small block [Re: MR_P_BODY] #1616620
05/06/14 04:21 PM
05/06/14 04:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Fixed
Well the obvious solution to me is put a 3.55 rear gear in it and have the same 1st and 2nd SLR but also have the ability to hit another gear at the top
Re: 4.86 gears with a small block [Re: HotRodDave] #1616621
05/06/14 04:43 PM
05/06/14 04:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Fixed
Most guys that run a glide dont play the SLR... they
dont want the hard shot on the line but look for
consistency.. gear has always been top end RPM to me..
if I wanted a better SLR I'd run a lower 1st gear
in the trans
Re: 4.86 gears with a small block [Re: HotRodDave] #1616622
05/06/14 04:45 PM
05/06/14 04:45 PM
PA.
"Little"John
"Little"John
PA.
Fixed
The Duster will eventually have a 4.30 gear in it as I really like that gear with a big block and a big block is in its future. I have 2 complete 4.30 Ford 9 inch set-ups for my Daytona but that doesn't do a lot of good went the Duster has a dana in it. With the new small block the 4.88 should be fine for now.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 4.86 gears with a small block [Re: pittsburghracer] #1616623
05/06/14 10:45 PM
05/06/14 10:45 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my duster had
4:88 dana
14x32 M/T slick
car weighted 3150 with driver
416 14:1-1
CNC Indybrocks
727 w/brake
5800 8" turbo action
shifted at 7800 crossed the strip around 7000
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 4.86 gears with a small block [Re: dusturbd340W5] #1616624
05/06/14 10:50 PM
05/06/14 10:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
my duster had
4:88 dana
14x32 M/T slick
416 14:1-1
CNC Indybrocks
727 w/brake
you shifted that thing at 7800?
Re: 4.86 gears with a small block [Re: MR_P_BODY] #1616625
05/07/14 12:43 AM
05/07/14 12:43 AM
CA.
CA.
running 152mph
[/qu
forgot to mention its a 416
Re: 4.86 gears with a small block [Re: RAY1969CARS] #1616626
05/07/14 01:14 AM
05/07/14 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
running 152mph
[/qu
Right now I'm shifting my 416 at 7400... but I think
I might try higher to see how it acts.. my 405 I
trapped at 8200
Re: 4.86 gears with a small block [Re: MR_P_BODY] #1616627
05/07/14 01:22 AM
05/07/14 01:22 AM
CA.
CA.
running 152mph
[/qu
trapped at 8200
is that in the rampage? What tire
