Re: 4.86 gears with a small block
[Re: RAY1969CARS]
#1616609
05/05/14 06:20 PM
05/05/14 06:20 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
4.88 dana gear, 14-32 M/T slick stock 1.76 gearset powerglide pump gas 408, 750 holly, app 11.4 comp shift@6400convertor stall 5100 550 solid lift cam with app 275CFM Edelbrock heads 2850 pound duster 6.30-6.40@106mph 1/8 mile best last year 10.06@130mph 1/4 mile Engine is out of guts at 1000ft due to small cam, low cfm numbers, and small carb. Stepping up to better combo this year.
[Re: RAY1969CARS]
#1616611
05/05/14 07:52 PM
05/05/14 07:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was running a 4.88, shifting at 8000, trapping at 8200, 14X31 turning 136 mph... I run a 4.56 now running 152mph
[Re: RAY1969CARS]
#1616614
05/05/14 10:27 PM
05/05/14 10:27 PM
MR_P_BODY
Is a 30 inch tire to small 12 1 w5 with 720 roller
With a 4.86 gear... depends on how quick you go... but I'd run it
[Re: RAY1969CARS]
#1616616
05/06/14 02:33 AM
05/06/14 02:33 AM
Posts: 2,864 IN
Irun5snd8th
IN
Variable will be your converter. However, typically a small block with a 4.86 goin 9.90 is gonna be about 131-134 mph with a 32 inch tall tire at around 7200 give or take 100 rpm. Shorten the tire and obviously the RPM's increase
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: HotRodDave]
#1616619
05/06/14 02:44 PM
05/06/14 02:44 PM
MR_P_BODY
Engine is out of guts at 1000ft due to DANG TRANS WONT SHIFT AGAIN
Fixed
Its still one to one in high gear
[Re: HotRodDave]
#1616621
05/06/14 04:43 PM
05/06/14 04:43 PM
MR_P_BODY
Fixed
Well the obvious solution to me is put a 3.55 rear gear in it and have the same 1st and 2nd SLR but also have the ability to hit another gear at the top
Most guys that run a glide dont play the SLR... they dont want the hard shot on the line but look for consistency.. gear has always been top end RPM to me.. if I wanted a better SLR I'd run a lower 1st gear in the trans
[Re: pittsburghracer]
#1616623
05/06/14 10:45 PM
05/06/14 10:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my duster had
4:88 dana 14x32 M/T slick car weighted 3150 with driver 416 14:1-1 CNC Indybrocks 727 w/brake 5800 8" turbo action shifted at 7800 crossed the strip around 7000
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1616624
05/06/14 10:50 PM
05/06/14 10:50 PM
Quicktree
my duster had
you shifted that thing at 7800?
[Re: MR_P_BODY]
#1616625
05/07/14 12:43 AM
05/07/14 12:43 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
I was running a 4.88, shifting at 8000, trapping at 8200, 14X31 turning 136 mph... I run a 4.56 now running 152mph [/qu
forgot to mention its a 416
[Re: RAY1969CARS]
#1616626
05/07/14 01:14 AM
05/07/14 01:14 AM
MR_P_BODY
Right now I'm shifting my 416 at 7400... but I think I might try higher to see how it acts.. my 405 I trapped at 8200
[Re: MR_P_BODY]
#1616627
05/07/14 01:22 AM
05/07/14 01:22 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
is that in the rampage? What tire
