96 grand cherokee stalling problem help please
#1616557
05/05/14 03:35 PM
05/05/14 03:35 PM
Posts: 763 Nashport, OH
chargers777
Nashport, OH
5.2 keeps stalling,bucking ,jerking while driving.new computer,crankshaft sensor,coil,cam sensor,tps cleaned iac and throttle body,new battery cleaned and checked all grounds,Fuel pressure is staedy at 49 psi.any ideas?Local garage cant figure it out either.No codes.Any ideas on what to check next?
Re: 96 grand cherokee stalling problem help please
[Re: chargers777]
#1616562
05/06/14 10:13 AM
05/06/14 10:13 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Check the O2 sensor.We had a few at work with no codes but the O2 would wack out.Created a lot of problems.You have to read live data to see what its doing.Just reading codes tells you very little.Rocky
Chrysler Firepower
[Re: Andrewh]
#1616564
05/06/14 11:21 AM
05/06/14 11:21 AM
therocks
Niles , Ohio
All 96s are OBD2.We had one also that had wiring problems.Jeeps were known for wiring problesm.Especially the tail park lights.Rocky
Chrysler Firepower
[Re: chargers777]
#1616567
05/06/14 06:54 PM
05/06/14 06:54 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Before I retired in 2011 I would work on these problems alot and this is one I would be using the Co-Pilot on as it can record the electronics when it acts up. Either the dealer can drive it with it on or they can let you take it as you just have to press a button when it acts up. This tool works awesome on problems like yours when they wont act up in the shop. Most of my years were with Dodge and I do remember on the Dodge trucks we had trouble with the dist (cam sensor) pick-up wires rubbing on the back of the drivers valve cover and shorting at times. I dont remember if the Jeep harness runs the same but you may want to check it. If you know a good Mopar tech you might want to ask him if they can use the Co-pilot on it as it usually takes any guess out of it. Ron
[Re: chargers777]
#1616570
05/06/14 09:43 PM
05/06/14 09:43 PM
Posts: 4,946 WI
Dcuda69
WI
stalling problem is intermittent.Normally runs great.I have put 2 new crankshaft sensors on it.Still does it.
OEM or aftermarket sensors? Just went something similar on a 01 Dak with a 3.9. Same basic setup. 2 different CKP sensors from the aftermarket...finally put a Chrysler part in it and problem solved.
[Re: Dcuda69]
#1616573
05/08/14 12:48 AM
05/08/14 12:48 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
If you are installing Brand X sensors instead of mopar ones, you are just installing problem after problem. Our Dealership will NOT use an after-market sensor...PERIOD.
