CD player in a challeneger
#1616549
05/05/14 02:57 PM
05/05/14 02:57 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
Looking to put a CD player into the dash on a challenger. Does anyone make a installation kit to do this?
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
Re: CD player in a challeneger
[Re: kissmyaspen]
#1616551
05/05/14 07:24 PM
05/05/14 07:24 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Pretty sure no one makes a kit.
It's been a long time since I did mine, but I don't think I needed a kit to do it anyway.
If I recall correctly, removing the radio left me with pretty much a standard DIN size hole in the dash. CD player came with a thin mounting surround that slid in and had tabs to fold out and secure it. The head unit then slid right into the thin surround piece. I used a section of thin metal strap (Home Depot probably) to make a rear support. Then custom spliced all the wiring.
Only drawback is that you will need to cut a small section off of the piece that mounts under the dash on the right side to make room for the radio faceplate. I don't think there is any way around that with an aftermarket radio. So if your car is all original look for a spare to cut up at the swap meets.
Another option would be to have the factory radio upgraded with new internals, and then use a trunk mounted CD changer. But, you're into big money going that direction.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: 71_deputy]
#1616554
05/06/14 01:34 PM
05/06/14 01:34 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I had to trim the lower dash trim to fit one in mine... luckily for me, it was trim that was cracked and I fixed, so didn't have to think twice about cutting it. You may be able to trim the cd player trim to fit, but they are usually thin and not much material to work with.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Michael Ecks]
#1616555
05/06/14 02:12 PM
05/06/14 02:12 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
I did the same thing you did. The metal "cage" for the CD player was a tight fit in my original dash opening, with no cutting required, and no additional bracing required. I found a CD player with a very thin rectangular face plate. I was able to fit the factory lower dash trim piece over the CD face plate, again with no cutting. Cutting my factory dash piece was not an option for me. If need be, I would have cut the lower edge off of the rectangular CD trim piece so that the factory trim piece would have fit properly with no cutting.
[Re: Michael Ecks]
#1616556
05/06/14 05:12 PM
05/06/14 05:12 PM
Posts: 4,748 Florida
BDW
Same here, standard metal cage fit opening. Did have to trim plastic bezel slightly. Look for radio with thin bszel.
