Engine gurus, Predator lifte angle/location..
#1616499
05/05/14 02:23 PM
05/05/14 02:23 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Looking for some input here before I pull the trigger. What are opinions on the lifter angle and placement on a raised block Predator engine? Is there any advantage to be had by moving the lifter location, ie spread out or stock? What do you consider the optimum lifter angle for a raised deck Predator deal? Any other thoughts on this deal? We are looking to make some decent power and trying to do my research to make sure we get a good, reliable, engine that makes some power.
Re: Engine gurus, Predator lifte angle/location..
[Re: boatracer572]
#1616502
05/06/14 01:28 AM
05/06/14 01:28 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Al, My KB has a 45* lifter angle and is a raised cam +.250". They are the stock spacing. I was told by Larry Olson (EPD) it would help to have the 45* angle with the Predator valve layout. Mike at Muscle Motors also said it would be better with a 45* angle.
