Master Cylinder? Update! #1615953
05/04/14 07:27 PM
05/04/14 07:27 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Put Wilwoods on all four corners, now the brakes stick....What the heck can cause it....I am thinking the master cylinder had the seal baked out of it due to fender well headers, but with only a week and a half to go, I need consultation....
Re: Master Cylinder? [Re: Dragula] #1615954
05/04/14 08:08 PM
05/04/14 08:08 PM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
Did you check the length of the pushrod to make sure it isn't too long? That is my first guess.
Re: Master Cylinder? [Re: Dragula] #1615955
05/04/14 08:38 PM
05/04/14 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Open a bleeder and see if it corrects it.. did you
center the caliper to the rotor
Re: Master Cylinder? [Re: MR_P_BODY] #1615956
05/04/14 10:09 PM
05/04/14 10:09 PM
Dragula Offline OP
Dragula  Offline OP
Calipers were all shimmed to center..and the brake pedal can still be pulled back further...This was a working setup when it had drums, so I am a little confused by this issue. If I tinker with the pedal, they all free up.
Re: Master Cylinder? [Re: Dragula] #1615957
05/04/14 10:22 PM
05/04/14 10:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
did you remove all the old plumbing the prop valve etc? you need to get rid of all that and run a new style 15/16 master cyl
Re: Master Cylinder? [Re: Quicktree] #1615958
05/04/14 10:24 PM
05/04/14 10:24 PM
Q
Quicktree Offline
Quicktree  Offline
Q
take the plunger off and see if that releases it?
Re: Master Cylinder? [Re: Quicktree] #1615959
05/04/14 10:35 PM
05/04/14 10:35 PM
Dragula Offline OP
Dragula  Offline OP
Prop valve is gone, one new AN03 line on each corner and the two off the master cylinder and the flex line to the rear axle
Re: Master Cylinder? [Re: Dragula] #1615960
05/04/14 10:44 PM
05/04/14 10:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
one other thing to check is the black flex line on the rear especially if it is stock, they will fail inside not letting pressure release
Re: Master Cylinder? [Re: Dragula] #1615961
05/04/14 11:12 PM
05/04/14 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Loosen the master a few threads and see if it still
does it
Re: Master Cylinder? [Re: Dragula] #1615962
05/04/14 11:57 PM
05/04/14 11:57 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Dragula when I put Wilwoods on my Cuda in the late 80's I had the same problem. If you are using the stock MC there is a small pressure valve(that keeps a small amount of pressure on at all times for the drum brakes) that can be removed from the MC. I used a small screw put it into the seat(where the line for the rear brakes entered to MC)and wiggled the seat out. I removed the valve and bingo no more drag. I've had this set up since 1988. If you have an aftermarket MC not sure if this will help. Wasn't sure which MC you were using.
Ok
Re: Master Cylinder? [Re: Quicktree] #1615963
05/05/14 07:43 AM
05/05/14 07:43 AM
Dragula Offline OP
Dragula  Offline OP
Replaced that with AN03...
Re: Master Cylinder? [Re: Dragula] #1615964
05/05/14 08:37 AM
05/05/14 08:37 AM
Q
Quicktree Offline
Quicktree  Offline
Q
nothing left but the master cyl, take the lines off and see if it releases.
Re: Master Cylinder? [Re: Quicktree] #1615965
05/05/14 08:49 AM
05/05/14 08:49 AM
Dragula Offline OP
Dragula  Offline OP
Ordered a new one along with the adjustable brake rod...I just don't get it though..
Re: Master Cylinder? [Re: Dragula] #1615966
05/05/14 12:28 PM
05/05/14 12:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
like cudatom said there is valve for drum brakes in those master cly. either that or you lean so far to the right that it keeps pressure on the brakes
Re: Master Cylinder? [Re: Dragula] #1615967
05/05/14 02:54 PM
05/05/14 02:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
All drum brake master cylinders have residual valves, usually around 10 lbs, in them somewhere, usually behind the brass seats that the brake lines hold in As already mentioned check that now by removing them with a # 8 sheet metal screw turn in 2 or 3 turns and then pry the seat out, the valves are rubber flapper valves with a small stainless spring inside the valves Remove them and throw them away and resaasembe the seats , make sure and crank down on the brake lines but don't strip the threads out of the master cylinders Same thing on the new matser cylinder also. On cars that have the master cylinders lower than the brake calipers you will need a 3 lb residual valves (Wilwood sells them )so the brake fluid won't drain back and overfill the master cylinders and leave air in the brake calipers
Re: Master Cylinder? [Re: Cab_Burge] #1615968
05/05/14 11:02 PM
05/05/14 11:02 PM
Dragula Offline OP
Dragula  Offline OP
It was an after market master cylinder....Just got the new one todayoks identical...
Re: Master Cylinder? [Re: Dragula] #1615969
05/05/14 11:12 PM
05/05/14 11:12 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Strange = Mopar.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Master Cylinder? [Re: pittsburghracer] #1615970
05/06/14 11:24 PM
05/06/14 11:24 PM
Dragula Offline OP
Dragula  Offline OP
What if there was old DOT fluid still in one of the lines when I put in the Wilwood fluid?
Re: Master Cylinder? [Re: Dragula] #1615971
05/06/14 11:30 PM
05/06/14 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its not OLD(ancient) ... run it... or bleed that
line more
Re: Master Cylinder? [Re: MR_P_BODY] #1615972
05/09/14 08:34 PM
05/09/14 08:34 PM
Dragula Offline OP
Dragula  Offline OP
Well....How about reversed lines off the Master Cylinder!!!!!
Bingo!!!!!
