Master Cylinder? Update!
#1615953
05/04/14 07:27 PM
05/04/14 07:27 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
Put Wilwoods on all four corners, now the brakes stick....What the heck can cause it....I am thinking the master cylinder had the seal baked out of it due to fender well headers, but with only a week and a half to go, I need consultation....
Re: Master Cylinder?
[Re: Quicktree]
#1615959
05/04/14 10:35 PM
05/04/14 10:35 PM
Dragula
did you remove all the old plumbing the prop valve etc? you need to get rid of all that and run a new style 15/16 master cyl
Prop valve is gone, one new AN03 line on each corner and the two off the master cylinder and the flex line to the rear axle
[Re: Dragula]
#1615962
05/04/14 11:57 PM
05/04/14 11:57 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Dragula when I put Wilwoods on my Cuda in the late 80's I had the same problem. If you are using the stock MC there is a small pressure valve(that keeps a small amount of pressure on at all times for the drum brakes) that can be removed from the MC. I used a small screw put it into the seat(where the line for the rear brakes entered to MC)and wiggled the seat out. I removed the valve and bingo no more drag. I've had this set up since 1988. If you have an aftermarket MC not sure if this will help. Wasn't sure which MC you were using.
Ok
[Re: Quicktree]
#1615963
05/05/14 07:43 AM
05/05/14 07:43 AM
Dragula
one other thing to check is the black flex line on the rear especially if it is stock, they will fail inside not letting pressure release
Replaced that with AN03...
[Re: Quicktree]
#1615965
05/05/14 08:49 AM
05/05/14 08:49 AM
Dragula
nothing left but the master cyl, take the lines off and see if it releases.
Ordered a new one along with the adjustable brake rod...I just don't get it though..
[Re: Dragula]
#1615966
05/05/14 12:28 PM
05/05/14 12:28 PM
Quicktree
like cudatom said there is valve for drum brakes in those master cly. either that or you lean so far to the right that it keeps pressure on the brakes
[Re: Dragula]
#1615971
05/06/14 11:30 PM
05/06/14 11:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What if there was old DOT fluid still in one of the lines when I put in the Wilwood fluid?
If its not OLD(ancient) ... run it... or bleed that line more
