Steering column grease ? #1615714
05/04/14 12:08 AM
05/04/14 12:08 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm restoring a couple steering columns and in disassembling them have discovered the remnants of the factory grease that looked more like earwax than grease
I have the crud all cleaned out and am reassembling everything, what type of grease do you guys like to use to lube the new parts.
Re: Steering column grease ? [Re: ScottSmith_Harms] #1615715
05/04/14 12:45 AM
05/04/14 12:45 AM
California
1970mopar Offline
1970mopar  Offline
California
scott,
i like to use pennzoil NLGI #2 Lithium grease
just a dab will do you.
Re: Steering column grease ? [Re: 1970mopar] #1615716
05/04/14 12:46 AM
05/04/14 12:46 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks Pete!
Re: Steering column grease ? [Re: ScottSmith_Harms] #1615717
05/04/14 01:24 AM
05/04/14 01:24 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've got a 30 year old tub of brown Valvoline grease that I've used in my two couplers. It looks like the original stuff I cleaned out of them....only clean. I also used it to lube other steering column pieces.
