72 E body electronics ? #1615706
05/04/14 12:07 AM
05/04/14 12:07 AM
KS
68SportSatvert Offline OP
KS
A friend is trying to sort out the electronics in his 72 Challenger. Apparently it has some type of one year only electronics. It has a module that connects a seatbelt sensor and several other sensors that control whether the car will start. Hopefully this makes sense. The goal is to bypass this. Any assistance will be greatly appreciated.
Re: 72 E body electronics ? [Re: 68SportSatvert] #1615707
05/04/14 12:50 AM
05/04/14 12:50 AM
SE PA
Yellow Fever Offline
SE PA
Re: 72 E body electronics ? [Re: 68SportSatvert] #1615708
05/04/14 12:56 AM
05/04/14 12:56 AM
run the "st" terminal on the ign switch out to the yellow wire on the "ign" terminal on the starter relay. Make sure the the "grn" terminal on the starter relay is being grounded in park/neutral via the NSS switch (in trans or clutch pedal) or just ground the male "grn" terminal on the starter relay to the nearby starter relay case mounting bolt. This will negate the safety feature & let it crank/start in any gear
Re: 72 E body electronics ? [Re: RapidRobert] #1615709
05/04/14 01:28 AM
05/04/14 01:28 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The seat belt inter lock system was only used in 74.
Re: 72 E body electronics ? [Re: burdar] #1615710
05/04/14 02:38 AM
05/04/14 02:38 AM
That's what I was thinking
Re: 72 E body electronics ? [Re: RapidRobert] #1615711
05/05/14 12:24 AM
05/05/14 12:24 AM
KS
KS
Thanks everyone! I haven't seen the car but it's been in the family for 15-20 years and is somewhat of a frankencar. I know very little about E bodies but he told me the car had the system on it and it's a 72. I'll verify. Thanks again! I can always rely on folks here for help.
Re: 72 E body electronics ? [Re: 68SportSatvert] #1615712
05/05/14 10:10 AM
05/05/14 10:10 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
after market stuff ?
Re: 72 E body electronics ? [Re: 71_deputy] #1615713
05/08/14 11:56 PM
05/08/14 11:56 PM
KS
KS
I confirmed it is a 74.
