just out of the blue.. wiring gremlins? 1968 A body #1615138
05/02/14 06:09 PM
05/02/14 06:09 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
front right turn signal light comes on when brake pedal is pushed, rear right brake light does not. left rear brake comes on. all other functions work?
why?
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: mcat4321] #1615139
05/02/14 07:11 PM
05/02/14 07:11 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Replace the rear bulb.
Sounds like the filament has broken and fallen across the other, thus back feeding the circuit.
It takes gasoline to interest me.
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: mcat4321] #1615140
05/02/14 07:35 PM
05/02/14 07:35 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
why?
Bad ground at one of the lamp sockets. Voltage will seek ground through the next easiest path. In this case its back feeding through the dash indicator.
Doug
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: mcat4321] #1615141
05/02/14 10:19 PM
05/02/14 10:19 PM
I'd seperate the TS/brake dangling pull apart connector under the steering column and (1) working with the column half of the connector with the stalk in nuetral there should be continuity between the white wire (which is the power in from the brake pedal switch) and 2 of the colored wires (A B) which are the L/R rear brake lights. raise the stalk & one of those 2 colored wires (A or B) must go dead and another (C) is now hot. move the stalk down and the other one (B or A) of those 2 colored wires goes dead & the original one that went dead is now hot again & (C) (out to the flasher) is still hot. (2) Working with the body half of the connector jump fire to the wire for (A) the left brake light (B) the pass brake light (C) the tail/lic plate lights (all on 1 wire). This'll tell you if the problem is in the TS switch/harness or rearward in the body wiring. www.mymopar.com will have the colors for you. You can also seperate the harness behind the drivers kick panel to narrow it down if it is a body harness problem
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: dvw] #1615142
05/02/14 10:26 PM
05/02/14 10:26 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i ran grounds to each socket, still the same..
the dash turn signal indicator does come on too with the front bulb. still no rear brake light either.
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: mcat4321] #1615143
05/03/14 12:12 AM
05/03/14 12:12 AM
that is normal as it is going to be on whenever the front large filament is on & they should be both blinking which ain't telling you anything that you dont already know. Stay on it & if I think of anything I'll holler
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: RapidRobert] #1615144
05/03/14 01:45 AM
05/03/14 01:45 AM
MNobody Offline
MNobody  Offline
Loosen and retighten the screws holding the instrument cluster in.
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: MNobody] #1615145
05/03/14 01:53 AM
05/03/14 01:53 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
First bet, easy bet, bad/dirty ground
Second bet, turn signal switch is partially failing... brake light circuit passes through the turn switch in the column. Had a Duster in High School, brake lights quit. Had no money then, but had a test light. Tracked down to turn signal switch failure. Installed a jumper on the switch, (don't remember how/where) and the brake lights worked afterwards, but the front signals lit with the brakes until I could afford a new switch. RR's input above should put you on the right track.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: just out of the blue.. wiring gremlins? 1968 A body [Re: mcat4321] #1615146
05/03/14 03:15 PM
05/03/14 03:15 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What could be bad on a 46 year old car
As already said, it is most likely a bad ground, or turn signal switch.
Jon (I think his user name is something like jsinthe rockies?) just re-wired his '68 Cuda using a modern type fuse box. Maybe he will chime in?
