front right turn signal light comes on when brake pedal is pushed, rear right brake light does not. left rear brake comes on. all other functions work?
why?
Bad ground at one of the lamp sockets. Voltage will seek ground through the next easiest path. In this case its back feeding through the dash indicator.
Doug
