Page 5 of 48 1 2 3 4 5 6 7 47 48
Re: Modern Bullitt build [Re: Keepat] #1614761
01/16/15 11:34 PM
01/16/15 11:34 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
Really nice work! and the wheels are like art!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Modern Bullitt build [Re: aspenrt360] #1614762
01/17/15 12:33 AM
01/17/15 12:33 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Congrats! Very very nice charger!
Matt
Re: Modern Bullitt build [Re: aspenrt360] #1614763
01/18/15 11:03 PM
01/18/15 11:03 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I test fit the 4 link rear today and put the rear wheels on the car for the 1st so I can setup the inter wheel wells. It’s not quit the milestone of a car coming out of the paint booth, but seeing it with the wheels on and the right stance is a close 2nd!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614764
01/19/15 12:03 PM
01/19/15 12:03 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Excellent work!
Re: Modern Bullitt build [Re: 69Cuda340S] #1614765
01/19/15 08:02 PM
01/19/15 08:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Excellent work!
Thank you sir!
Re: Modern Bullitt build [Re: aspenrt360] #1614766
01/22/15 12:52 PM
01/22/15 12:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Before the new trunk floor gets installed I moved the wheel well flange in 2 ¼” on each side to keep an original look to the floor.
Pat
Re: Modern Bullitt build [Re: aspenrt360] #1614767
02/07/15 12:33 AM
02/07/15 12:33 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Remove what was left of the trunk floor and cut some dead weight out of the frame by removing the rear spring mounts. I also removed the left side trunk drop to do a little rust repair that I found when the trunk floor was removed. I could’ve bought a new trunk drop but I enjoy saving as much of the original steel as I can.
Pat
Re: Modern Bullitt build [Re: aspenrt360] #1614768
02/22/15 11:49 PM
02/22/15 11:49 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Out of town for a few days working at the Miami boat show, but got back on the Charger this weekend. Remove most of the paint, undercoating, and surface rust in the trunk.
Pat
Heat-gun and a putty knife and then wipe down with lacquer thinner makes quick remove of the original sound deadening.
Re: Modern Bullitt build [Re: Keepat] #1614769
02/23/15 01:44 AM
02/23/15 01:44 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
How do you plan to put the one piece trunk pan in? Just curious as I only seen it done with the quarters cut off.
Re: Modern Bullitt build [Re: moparpollack] #1614770
02/23/15 11:49 AM
02/23/15 11:49 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With the inter wheel wells out and the package tray cross braces removed the full trunk pan will go in from the back seat, then I will install the inter wheel well.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614771
02/25/15 12:16 PM
02/25/15 12:16 PM
Maryland
rhamson Online content
rhamson  Online Content
Maryland
Nice work Pat! Keep it up.
Re: Modern Bullitt build [Re: rhamson] #1614772
02/28/15 01:10 PM
02/28/15 01:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Before installing the trunk floor I started on the back window as it would be easier to clean up the welds under the window frame without the trunk floor.
Made a few template of the corner before cutting the rust out as to match the shape.
Welded in the lower half of the corner before cutting out the top half to help hold the shape.
Use the trim to confirm the shape as I tacked welded the new metal in.
One corner done and one to go.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614773
02/28/15 01:48 PM
02/28/15 01:48 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Very impressive to say the least, I am enjoying following this thread........
Admiration For Multiple Carburetor Vehicles...
Re: Modern Bullitt build [Re: Stewpar] #1614774
02/28/15 02:41 PM
02/28/15 02:41 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!
Re: Modern Bullitt build [Re: Keepat] #1614775
03/01/15 01:53 AM
03/01/15 01:53 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Nice work on that window channel.
Re: Modern Bullitt build [Re: aspenrt360] #1614776
03/04/15 12:54 AM
03/04/15 12:54 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The right side was a little more work but turned out nice.
Next project is the trunk floor and mini tubs.
Thanks!
Pat
Re: Modern Bullitt build [Re: aspenrt360] #1614777
03/08/15 01:09 AM
03/08/15 01:09 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Test fit the trunk floor today so I can measure for the inner wheel wells. With the back seat cross braces removed and upper corners slightly bent up. The only other modification need was to bend the right side aft wheel well corner which I was planning on as I didn’t weld that corner on yet in anticipation to a tight fit at the widest point of the trunk floor.
Pat
Re: Modern Bullitt build [Re: aspenrt360] #1614778
03/13/15 12:24 PM
03/13/15 12:24 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Fit and butt welded the US Car Tool mini tub kit to one of the wheel wells. The left side fit great and I’ll let you how the right side works soon. Would be nice if someone made wide stock looking wheel well like they have for GM & Ford cars!
I screwed on the extension to the outer wheel well. The shape of the kit is spot on!
With the extension in place I screwed the inter wheel well on so I could remove it as one part to weld it together.
Added about 2 ½” to the wheel well, a lot of work for a 335 tire but it will look cool!
Thank you!
Pat
Re: Modern Bullitt build [Re: aspenrt360] #1614779
03/15/15 12:08 AM
03/15/15 12:08 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished the front wheel well floor flange and test fit the left wheel tub. Now on to the right side.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614780
03/15/15 01:43 AM
03/15/15 01:43 AM
Oakley CA
69charger440_6pa Offline
Oakley CA
nicely done sir!
you are making me consider ripping my rear wheel wells out so I can do the same.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
