Re: Modern Bullitt build
[Re: ihv800]
#1614742
11/16/14 11:45 AM
11/16/14 11:45 AM
Posts: 676 Maryland
Keepat
Maryland
Build looks awesome. What is your procedure for metal finishing your welds down on the patch work? It looks fantastic!
I'm not sure I have any secret techniques that you can't already find online. The most important thing to remember is taking your time and don't let the panel get too hot. As I stitch weld I'd like to grind down the small welds close to the panel surface as I go Instead of grinding all the welds down when you're done. This helps keep the panel temperature low and It also helps when you're connecting the stitch welds as the panel thickness is more consistent with your amp setting on the welder. Thanks Pat
[Re: Keepat]
#1614745
11/24/14 01:18 AM
11/24/14 01:18 AM
moparpollack
Lil Herman
Lil Herman
85086
Sweet looking bullet!
[Re: rhamson]
#1614751
12/18/14 12:06 PM
12/18/14 12:06 PM
Posts: 676 Maryland
Keepat
Maryland
Picked up a cool sissor lift for the shop and it will work get to put the motor in Thanks Pat
[Re: Keepat]
#1614756
01/11/15 01:06 AM
01/11/15 01:06 AM
Posts: 676 Maryland
Keepat
Maryland
I have the spring relocation mounts installed. The US Car Tool spring mount have an alignment flange that bolts to the original forward spring perch but I had to cut it off as the Reilly Motorsport Street Lynx centers to the original frame (36 ¾”) I used the frame cutouts to make templates to match the shape on the new spring mounts. With spring mounts tacked welded on I will fit the upper crossbar before welding in. Thanks Pat
[Re: Keepat]
#1614758
01/14/15 07:25 PM
01/14/15 07:25 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Wow... Very impressive.. I dig the vision of the wheels.....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1614759
01/16/15 11:30 PM
01/16/15 11:30 PM
Posts: 676 Maryland
Keepat
Maryland
Thank You sir!
