ATI VS. FLUIDAMPR #161462
12/05/08 01:34 AM
12/05/08 01:34 AM
CHANDLER, AZ
512 VALIANT Offline OP
CHANDLER, AZ
WHICH ONE IS BETTER AND WHY? MY MACHINRE SHOP USES ATI, BUT SAYS FLUIDAMPR IS GOOD. I HAVE A NEW FLUIDAMPR IN THE BOX. IS THERE ANY REASON I SHOULD NOT USE IT? I AM BUILDING A LOW DECK 512.
Re: ATI VS. FLUIDAMPR [Re: 512 VALIANT] #161463
12/05/08 02:10 AM
12/05/08 02:10 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It just boils down to personal choice. Myself, I don't care for any brand of damper that has fluid, because I have personally seen that fluid harden and jell inside. Also, you can't check the balance of a fluid damper, you just have to take their word for it. Most builders, me included, prefer the ATI unit, although there are some diehard fluid damper supporters.
Monte
Re: ATI VS. FLUIDAMPR [Re: 512 VALIANT] #161464
12/05/08 02:13 AM
12/05/08 02:13 AM
AndyF Online content
AndyF  Online Content
I've run both, never seen any problems with either. I've had a Fluidampr on my low deck street motors for years. I usually use an ATI on race motors but that is because ATI has a bunch of different options that Fluidampr doesn't have.
Re: ATI VS. FLUIDAMPR [Re: AndyF] #161465
12/05/08 03:01 AM
12/05/08 03:01 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
ATI dampner
and ati converter
Re: ATI VS. FLUIDAMPR [Re: 70blackfish] #161466
12/05/08 07:03 AM
12/05/08 07:03 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
ATI, I've seen a fluid style dampner die firsthand, (not a fluidampr), it cost the owner $14,000. Dave
Re: ATI VS. FLUIDAMPR [Re: quickd100] #161467
12/05/08 08:36 AM
12/05/08 08:36 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
ATI hands down!!
Fluid Dampers work on Diesels with a lower RPM. My machinist did an experiment and a fluidamper was very incosistant when he spun a crank up 3 different times with the same crank, and damper. Would never give him any of the same readings. The jejjy is never in the same place when its spun. it settles in a different place when it stops, and they always seem to have an air pocket in them for expantion.
Just my
Re: ATI VS. FLUIDAMPR [Re: Moparnut426] #161468
12/05/08 09:29 AM
12/05/08 09:29 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
ATI here as well. Keep the fluid damper. When I asked them how it dampens the motor correctly at different temps, the other end of the phone went silent.
Re: ATI VS. FLUIDAMPR [Re: Moparnut426] #161469
12/05/08 10:42 AM
12/05/08 10:42 AM
CHANDLER, AZ
CHANDLER, AZ
THANKS FOR EVERYONES INPUT. LOOKS LIKE ATI IS THE WINNER. I JUST WONDER WHAT MAKES THE ATI DAMPER BETTER AND IF IT WOULD HAVE THE SAME RESULTS ON MOPARNUT426 MACHINE SHOP TEST?? OR JUST DEAL WITH IT AND BUY AN ATI UNIT??
HEY BUY THE WAY, DOES ANY ONE NEED A GOOD DEAL ON A FLUIDAMPR?
Re: ATI VS. FLUIDAMPR [Re: 512 VALIANT] #161470
12/05/08 11:04 AM
12/05/08 11:04 AM
you actually can test a fluid style damper on a balance machine, just not at the typical 500 rpm speed that cranks are usually balanced at.
spinning them up un the 700+ range they will go neutral if they're working right, below that they won't neutral out. once they neutral out you can decrease the rpm to around 600-650 and they'll stay neutral.
that machine shop test that Moparnut mentioned is typical at 500 rpm.
both ATI and Fluidampr brands are expensive. we have some less expensive elastomer (ati) style dampers for those on a limited budget that seem to perform quite well also.
Re: ATI VS. FLUIDAMPR #161471
12/05/08 11:36 AM
12/05/08 11:36 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Honestly when it comes down to same for same money, Ill take the company with a unquestioned reputation for quality.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: ATI VS. FLUIDAMPR [Re: HemiDart68] #161472
12/05/08 11:49 AM
12/05/08 11:49 AM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
ATI here.
Re: ATI VS. FLUIDAMPR [Re: 70RTRacer] #161473
12/05/08 12:35 PM
12/05/08 12:35 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
ATI
Re: ATI VS. FLUIDAMPR [Re: 512 VALIANT] #161474
12/05/08 12:42 PM
12/05/08 12:42 PM
ohio
prochamp Offline
prochamp  Offline
ohio
i have 2 340's one has fluidamper the other ati.i haven't seen anything wrong (bearing wise )with either motor.both motors are run at 7600 rpm.that being said i would choose ati for two reasons.it is rebuildable and it is much lighter.
Re: ATI VS. FLUIDAMPR [Re: AndyF] #161475
12/05/08 12:52 PM
12/05/08 12:52 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Re: ATI VS. FLUIDAMPR [Re: prochamp] #161476
12/05/08 12:54 PM
12/05/08 12:54 PM
CHANDLER, AZ
CHANDLER, AZ
THANK YOU PROCHAMP, YOU JUST PUT THE LAST NAIL IN THE COFFIN. I WILL USE THE ATI. I DO NOT WANT TO SKIMP OUT ON THIS W/ ALL THE $$$$ I ALREADY HAVE IN IT. THANK YOU FOR EVERYONE WHO GAVE INPUT ON THIS SUBJECT.
Re: ATI VS. FLUIDAMPR [Re: 512 VALIANT] #161477
12/20/08 07:37 PM
12/20/08 07:37 PM
detroit mich
stevehiss Offline
stevehiss  Offline
detroit mich
my fluiddampner has one season under its belt on my 512 , so far so good
I DARE TO BE DIFFERENT
Re: ATI VS. FLUIDAMPR [Re: stevehiss] #161478
12/20/08 08:17 PM
12/20/08 08:17 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i use a fluid dampr also but after seeing it work on the blown/2K HP TD lake erie monster i would not be afraid to use the ATI.
Re: ATI VS. FLUIDAMPR [Re: 512 VALIANT] #161479
12/21/08 01:04 AM
12/21/08 01:04 AM
Fla
Mike T Offline
Mike T  Offline
Fla
Both good stuff from our exp.Never had trouble with either.
