Re: ATI VS. FLUIDAMPR
[Re: 512 VALIANT]
#161470
12/05/08 11:04 AM
12/05/08 11:04 AM
you actually can test a fluid style damper on a balance machine, just not at the typical 500 rpm speed that cranks are usually balanced at. spinning them up un the 700+ range they will go neutral if they're working right, below that they won't neutral out. once they neutral out you can decrease the rpm to around 600-650 and they'll stay neutral. that machine shop test that Moparnut mentioned is typical at 500 rpm.
both ATI and Fluidampr brands are expensive. we have some less expensive elastomer (ati) style dampers for those on a limited budget that seem to perform quite well also.
#161471
12/05/08 11:36 AM
12/05/08 11:36 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Honestly when it comes down to same for same money, Ill take the company with a unquestioned reputation for quality.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: AndyF]
#161475
12/05/08 12:52 PM
12/05/08 12:52 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I've run both, never seen any problems with either. I've had a Fluidampr on my low deck street motors for years. I usually use an ATI on race motors but that is because ATI has a bunch of different options that Fluidampr doesn't have.
[Re: 512 VALIANT]
#161477
12/20/08 07:37 PM
12/20/08 07:37 PM
Posts: 52 detroit mich
stevehiss
detroit mich
my fluiddampner has one season under its belt on my 512 , so far so good
I DARE TO BE DIFFERENT
