Main bore size of a 383/400 #1614463
05/01/14 01:27 AM
05/01/14 01:27 AM
Stuttgart, Arkansas
rickseeman Offline OP
Stuttgart, Arkansas
I can't believe with all my Mopar books I can't find the main bore min-max size for a 400. Thanks for your help.
2011 Drag Pak Challenger
Re: Main bore size of a 383/400 [Re: rickseeman] #1614464
05/01/14 01:52 AM
05/01/14 01:52 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well the stock-min size for the 400 is 4.342. As for max, less is better. Keep the bores as thick as possible. Dont try to gain CI with the bores.
Re: Main bore size of a 383/400 [Re: Sport440] #1614465
05/01/14 02:13 AM
05/01/14 02:13 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
You're not going to find anyone publishing a "max overbore". It depends on the particular block you're working with. Have it sonic checked.
Re: Main bore size of a 383/400 [Re: Sport440] #1614466
05/01/14 02:23 AM
05/01/14 02:23 AM
Arizona
Chris'sBarracuda Offline
Arizona
Don't think that's what he's asking..
Crankshaft..
Chris.
Re: Main bore size of a 383/400 [Re: Chris'sBarracuda] #1614467
05/01/14 03:23 AM
05/01/14 03:23 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Should be in the service manual and any of the bearing catalogs
Leave the gun.......take the Cannoli's....Mike
Re: Main bore size of a 383/400 [Re: mike s] #1614468
05/01/14 11:31 AM
05/01/14 11:31 AM
Stuttgart, Arkansas
Stuttgart, Arkansas
Yes, what I need is the main bore spec. An RB is 2.9425-2.943 but I don't have the Chrysler specs for a B engine. Thanks.
Re: Main bore size of a 383/400 [Re: rickseeman] #1614469
05/01/14 12:18 PM
05/01/14 12:18 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Look in a clevite bearing book, it lists all housing bore sizes.
Re: Main bore size of a 383/400 [Re: moparlifer] #1614470
05/01/14 12:22 PM
05/01/14 12:22 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
I have that book but I would rather hear it from Chrysler.
Re: Main bore size of a 383/400 [Re: rickseeman] #1614471
05/01/14 12:29 PM
05/01/14 12:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I show is 2.625 but check some other data also..
I'm not sure on this the way its written
Re: Main bore size of a 383/400 [Re: MR_P_BODY] #1614472
05/01/14 12:55 PM
05/01/14 12:55 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
There should be a high and low spec. When line honing 5 main bores at once it would be a little difficult to hit them all at the same time within a tenth.
Re: Main bore size of a 383/400 [Re: rickseeman] #1614473
05/01/14 12:58 PM
05/01/14 12:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats why I said check other data... this didnt have
a max/min.. all the other data on that engine did
show max/min
Re: Main bore size of a 383/400 [Re: MR_P_BODY] #1614474
05/01/14 06:27 PM
05/01/14 06:27 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I use an old Vandervell bearings catalog (#112) which has most measures in inches and metric. For the B Mopar engine it reads:
Main bearing housing 2.8175"-2.8180"
Crankpin mains 2.6245" - 2.6255"
I have used these measures both for checking/lineboring and crankgrinding and it works out fine; I normally grind the crank at 2.6250 as a base for the undersizes. Hope this helps you out!
