Sm Block Oil Filter Leak
#161416
12/04/08 11:44 PM
12/04/08 11:44 PM
Posts: 3,378 KY USA
mopargem
KY USA
My 71 340 started leaking oil at the 90* adapter where it mates to the block. It's a pretty good leak. I used a gasket from my stash but not sure if it was the right type, the diam. was correct. Last guy just used silicone. Any insight to how these mount and what gaskets go where? A good pic would be great. I would do away with it but the car has headers and I think the filter will hit them sticking straight out. Thanks! Tim
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
Re: Sm Block Oil Filter Leak
[Re: mopargem]
#161417
12/05/08 12:10 AM
12/05/08 12:10 AM
RapidRobert
felpro makes a thicker large gasket that goes into the block that works better than the Mopar one. Clean the recess in the block well & use some sealer on it. The other 2 gaskets, the thin one goes under the bolt head & the thick cork one goes inside on the bolt shank.
[Re: kams]
#161419
12/05/08 09:12 AM
12/05/08 09:12 AM
Posts: 3,378 KY USA
mopargem
KY USA
Ok, thanks guys, I may try the short filter first. Tim
