1969 GTX gauge cluster options? #1614123
04/30/14 02:32 PM
04/30/14 02:32 PM
Moxee Washington
shortbox68 Offline OP
Moxee Washington
Curious to now if it was common to have a tach or clock and still have the clear lens stenciled with the wiper washer labels? I have a 150 speedo and need to determine the correct lens. Some one has cut out the tach/clock portion of the cluster for an aftermarket oil pressure gauge.
Re: 1969 GTX gauge cluster options? [Re: shortbox68] #1614124
04/30/14 04:47 PM
04/30/14 04:47 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I think the car's Scheduled Production Date may have something to do with the layout also. Do you know the car's SPD?
Re: 1969 GTX gauge cluster options? [Re: shortbox68] #1614125
04/30/14 04:57 PM
04/30/14 04:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
My '69 GTX is a Dec 16, 1968 SPD with a tach and has the washer wiper on the lens and on the switch panel.
(photo taken before resto )
Re: 1969 GTX gauge cluster options? [Re: A12] #1614126
04/30/14 05:10 PM
04/30/14 05:10 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Also, which plant?
Re: 1969 GTX gauge cluster options? [Re: shortbox68] #1614127
04/30/14 07:36 PM
04/30/14 07:36 PM
cbusters Offline
cbusters  Offline
I did that to an old RR 4 speed car that I had. Also put a 150 speedometer in it. Cut a hole in the dummy plate that mounts from the rear. Are you sure it is a GTX? (Twilight Zone music)
Re: 1969 GTX gauge cluster options? [Re: 6bblgt] #1614128
04/30/14 07:40 PM
04/30/14 07:40 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Also, which plant?
My GTX was an "E" LA plant car
Re: 1969 GTX gauge cluster options? [Re: shortbox68] #1614129
05/02/14 01:13 PM
05/02/14 01:13 PM
Moxee Washington
Moxee Washington
Thanks, I will determine the SPD and get back to you.
