Re: 1969 GTX gauge cluster options?
[Re: A12]
#1614126
04/30/14 05:10 PM
04/30/14 05:10 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
I think the car's Scheduled Production Date may have something to do with the layout also. Do you know the car's SPD?
Also, which plant?
[Re: shortbox68]
#1614127
04/30/14 07:36 PM
04/30/14 07:36 PM
Posts: 784 Florida
cbusters
Curious to now if it was common to have a tach or clock and still have the clear lens stenciled with the wiper washer labels? I have a 150 speedo and need to determine the correct lens. Some one has cut out the tach/clock portion of the cluster for an aftermarket oil pressure gauge.
I did that to an old RR 4 speed car that I had. Also put a 150 speedometer in it. Cut a hole in the dummy plate that mounts from the rear. Are you sure it is a GTX? (Twilight Zone music)
[Re: 6bblgt]
#1614128
04/30/14 07:40 PM
04/30/14 07:40 PM
Posts: 21,505 N.E. OHIO, USA
A12
N.E. OHIO, USA
Also, which plant?
My GTX was an "E" LA plant car
