Page 7 of 13 1 2 5 6 7 8 9 12 13
Re: "Custom 33" [Re: 67HEMI] #1613591
02/18/15 11:37 PM
02/18/15 11:37 PM
moparx Offline
moparx  Offline
Hey Dave, went with safety glass all the way around. Auto glass guy up in my area cut them. Anxious to see what your frame looks like.
John this is the narrowed version of my frame with the rear tires and wheels I am using. Hope to meet Matt this weekend and do the "swap".
i think your pinion angle needs some work. just kidding ! how much clearance is there between the side wall and the frame rail ? also, how much tub area was added to the body from stock ?
Re: "Custom 33" [Re: moparx] #1613592
02/19/15 02:18 AM
02/19/15 02:18 AM
IN
Matt Erich Offline
Matt Erich  Offline
IN
The car was narrowed 7" and the body has been tubbed 9" He has 1" between tire and frame and 2" between tire and fender. Here is another pictures of the car with the body down on it.
Owner of Custom33.com 1933 Plymouth Coupe and Roadster Kits
Re: "Custom 33" [Re: Matt Erich] #1613593
02/22/15 11:24 PM
02/22/15 11:24 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
David's new 1933 Plymouth Coupe loaded on the trailer. The 2 feet of snow didnt stop this build.
Re: "Custom 33" [Re: Matt Erich] #1613594
02/22/15 11:25 PM
02/22/15 11:25 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
front view
Re: "Custom 33" [Re: Matt Erich] #1613595
02/22/15 11:27 PM
02/22/15 11:27 PM
IN
Matt Erich Offline
Matt Erich  Offline
IN
Loaded in the trailer and headed home. David has a new project for this spring! Please call or msg on here if you have any questions about Custom33 cars or builds!
Re: "Custom 33" [Re: Matt Erich] #1613596
02/24/15 12:25 PM
02/24/15 12:25 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Since my 33 is going to be a "driver", it needed wipers. Went with a universal kit from "Specialty Power Windows". Nice kit. Great instructions. They wanted the wiper arm posts to be at 90* from the windshield - couldn't get there with the 33 and had to settle for about 70*. Wood blades are for moc-up only until I get the window trim installed and I know just what blade length I can use.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613597
02/24/15 12:29 PM
02/24/15 12:29 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Outside pick w/blades "at rest".
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613598
02/28/15 12:00 PM
02/28/15 12:00 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Battery location.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613599
02/28/15 12:02 PM
02/28/15 12:02 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Nuther pic.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613600
03/11/15 12:09 PM
03/11/15 12:09 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I like the wiper setup and the battery John.....now what is behind door # 2 on the left?
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: "Custom 33" [Re: 67HEMI] #1613601
03/12/15 12:43 AM
03/12/15 12:43 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Wife requested it???
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613602
03/18/15 07:40 PM
03/18/15 07:40 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
If you are not running a SB Chev, be prepared to do a lot of bracket fabing. I actually was able to use a Chevy mount for the compressor with some modifications. Probably be time and $ ahead if I just bought a Chevy crate motor and slapped a Moper decal on the valve covers.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613603
03/18/15 07:42 PM
03/18/15 07:42 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
from the top
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613604
03/18/15 10:05 PM
03/18/15 10:05 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Yup they are hard to come by.
Re: "Custom 33" [Re: Crizila] #1613605
03/19/15 09:54 PM
03/19/15 09:54 PM
moparx Offline
moparx  Offline
the brackets look good ! what is your pulley ratio between the crank and water pump ? or what is the diameter of each ?
Re: "Custom 33" [Re: moparx] #1613606
03/20/15 01:20 AM
03/20/15 01:20 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
.88:1 ( crank is 5.75" and pump pulley is 6.5". Not too concerned with the H2O pump output, but alternator (75amp) to crank ratio is 2.09:1. Most street stuff is 3:1. Might be a little slow at idle. Running a 3.55 gear, so no problems at cruise. Alternator is a 1 wire Power Master and it has a hi rise time, which should help. Gotta try it and see.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1613607
03/22/15 12:42 PM
03/22/15 12:42 PM
67HEMI Offline
67HEMI  Offline
I chose not to use a chevy motor in mine. Not going to have a/c either so I just took 4 inches out of the firewall for ventilation and to make room for the powerplant!
Re: "Custom 33" [Re: 67HEMI] #1613608
03/22/15 12:47 PM
03/22/15 12:47 PM
67HEMI Offline
67HEMI  Offline
Got the HEMI set in so I can mock up some mounting tabs.
Re: "Custom 33" [Re: 67HEMI] #1613609
03/22/15 12:49 PM
03/22/15 12:49 PM
67HEMI Offline
67HEMI  Offline
"Roadkill" view.
Re: "Custom 33" [Re: 67HEMI] #1613610
03/22/15 12:51 PM
03/22/15 12:51 PM
67HEMI Offline
67HEMI  Offline
Drivers view.
