New wiper motor is in, but I have a question still? #1613104
04/28/14 01:01 PM
04/28/14 01:01 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I see in some of the ads for the windshield wiper motor ('76 D100) that they indicate that the motor is for "Front; Motor without Washer Pump" (Rock auto.com). I'm wondering what this means? I also found this one on E bag.
http://www.ebay.com/itm/231074384450?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
My truck has a washer pump (activated by the dash mount switch). Will this motor not work for my application?
Re: I'm replacing my wiper motor, but I have a question? [Re: bigblock340power] #1613105
04/28/14 02:17 PM
04/28/14 02:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Any reason you can't just take your old one to a local parts store and march it up with a new one? I don't see why your washer pump wouldn't work if it's the one mounted on the radiator support with the little pump motor on the bottom of it.
Re: I'm replacing my wiper motor, but I have a question? [Re: stumpy] #1613106
04/28/14 02:37 PM
04/28/14 02:37 PM
Elk Grove, Calif.
Elk Grove, Calif.
Yep, I just got back from doing that. We talked over the window washer pump thing. Seems it has nothing to do with the wiper motor. I'm just wondering why they would put this statement/stipulation in "Front; Motor without Washer Pump" for any reason? I went to Oreilly, found the one I needed. Cost a couple dollars more than Rock auto, but I'll have it here by 10:30 today! So out to take the old one out.
Re: I'm replacing my wiper motor, but I have a question? [Re: bigblock340power] #1613107
04/28/14 03:08 PM
04/28/14 03:08 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Chevrolet does that on there 70's & 80's truck they have the washer pump on the wiper motor which is driven by the wiper motor, dodge never did that "thank god"
Re: I'm replacing my wiper motor, but I have a question? [Re: 98RAM1500] #1613108
04/29/14 10:24 AM
04/29/14 10:24 AM
scratchnfotraction Offline
that way counter jerk knows it is not the wiper washer motor on the washer bottle.
Re: I'm replacing my wiper motor, but I have a question? [Re: scratchnfotraction] #1613109
05/05/14 03:48 PM
05/05/14 03:48 PM
Elk Grove, Calif.
Elk Grove, Calif.
Ok, new wiper motor's in now. Tested it and still won't park, and doesn't have two speeds either (but neither did the old one). I checked all the wiring, connections, and continuity. Thinking it's the switch. What do you motor heads out there think?
Re: I'm replacing my wiper motor, but I have a question? [Re: bigblock340power] #1613110
05/05/14 05:46 PM
05/05/14 05:46 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Run a ground wire from the battery right to the case of the motor; see if it will park then.
Re: I'm replacing my wiper motor, but I have a question? [Re: WyleECoyote] #1613111
05/05/14 10:50 PM
05/05/14 10:50 PM
Elk Grove, Calif.
Elk Grove, Calif.
If I do this, and it parks, that means? But if doesn't park (or does the same thing), that means?
Re: I'm replacing my wiper motor, but I have a question? [Re: bigblock340power] #1613112
05/06/14 01:17 AM
05/06/14 01:17 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Does it have the woven ground strap ?
If the ground wire makes it work you need a ground wire.
If that doesnt work Id try changing the switch.
I am truckless..
Re: I'm replacing my wiper motor, but I have a question? [Re: 340SHORTY] #1613113
05/06/14 12:33 PM
05/06/14 12:33 PM
Elk Grove, Calif.
Elk Grove, Calif.
No, it's a solid thin brass strap.
Tried the ground wire idea to the (-) battery post, no dice/same thing. It's looking more and more like the switch I guess.
A few other questions: This wiper motor looks like a two speed wiper motor to me (as does the old one). Mostly cause of it's configuration/case (I've seen in cars). The wiper motor I have in my duster looks completely different (it's a three speed). Am I correct in assuming this is true in trucks too? Did the trucks come with three speed wipers (as an option?)? So (of course) the switch should be for a two speed too? I just don't want to mix/match components.
Thanks again.
Oh! I'm having a hard time finding these wiper motor switches! Anybody
Re: I'm replacing my wiper motor, but I have a question? [Re: bigblock340power] #1613114
05/06/14 07:33 PM
05/06/14 07:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why is that??? 72-80 d series trucks all use the same switch.
Re: I'm replacing my wiper motor, but I have a question? [Re: NITROUSN] #1613115
05/06/14 10:51 PM
05/06/14 10:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
35 + year old truck..
theres a couple on the bag, but they must be gold plated.
I am truckless..
Re: I'm replacing my wiper motor, but I have a question? [Re: NITROUSN] #1613116
05/06/14 11:19 PM
05/06/14 11:19 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
this place has one dunno if it's new or used for 20 bucks, I bought a cargo light assembly from them and it was used, but in great shape & for 25 bucks couldn't argue with that price
http://www.mopartruckparts.com/group-08.html
Re: I'm replacing my wiper motor, but I have a question? [Re: 98RAM1500] #1613117
05/07/14 01:07 AM
05/07/14 01:07 AM
Elk Grove, Calif.
Elk Grove, Calif.
Yup, that's where I ended up getting one. All in all, $28.00 bucks (used, and guaranteed to work OK). No parts places have them, and very few others too!
