Aluminum block Main clearance #1612899
04/27/14 10:28 PM
04/27/14 10:28 PM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
What are you guys running for main bearing clearance with an Indy Max aluminum block?
Re: Aluminum block Main clearance [Re: jafr] #1612900
04/28/14 09:31 AM
04/28/14 09:31 AM
Arizona
Chris'sBarracuda Offline
Arizona
I've got mine at .0038..
Chris..
Re: Aluminum block Main clearance [Re: Chris'sBarracuda] #1612901
04/28/14 01:51 PM
04/28/14 01:51 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
mine is at .0037 also I run a complete milodon external oil system, my rods are at .003
Re: Aluminum block Main clearance [Re: jafr] #1612902
04/29/14 01:15 AM
04/29/14 01:15 AM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Mine are .0035
Re: Aluminum block Main clearance [Re: PLUM BAD] #1612903
04/29/14 05:42 PM
04/29/14 05:42 PM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
Thanks, guys. I was shooting for .0035 on the mains and the most I could get was .0028 with a speed-pro M-119 bearing. I can tell you from experience it didn't like the clearance that tight, 1 pass and I found metal in the filter. I pulled the motor before any major damage occurred and found the metal was coming from #4 main.
I am going to take the block and crank to the machine shop and have the mains and crank checked. I hate to turn the crank to get an extra .0007 clearance. We shall see what the machine shop has to say.
Re: Aluminum block Main clearance [Re: jafr] #1612904
04/29/14 06:14 PM
04/29/14 06:14 PM
an8sec70cuda Offline
Mine are also .0035"...KB block.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aluminum block Main clearance [Re: jafr] #1612905
04/29/14 09:53 PM
04/29/14 09:53 PM
Have the shop check the main bore diameter, it is way easier to open it up .0005 to .00010 than it is to grind that amount off of a crank
Re: Aluminum block Main clearance [Re: Cab_Burge] #1612906
04/30/14 01:30 AM
04/30/14 01:30 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It is an aluminum block. It does expand, no? I would think you would want a little under .003 cold if anything. Just my 2 cents.
2011 Drag Pak Challenger
Re: Aluminum block Main clearance [Re: rickseeman] #1612907
04/30/14 02:14 AM
04/30/14 02:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
But it expands in all directions... not just inward
Re: Aluminum block Main clearance [Re: MR_P_BODY] #1612908
04/30/14 10:45 AM
04/30/14 10:45 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
Another reason I was asking about the clearance was if you need to set the valve lash tighter because it opens up, will the main clearance open also?
Re: Aluminum block Main clearance [Re: MR_P_BODY] #1612909
04/30/14 04:35 PM
04/30/14 04:35 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
But the caps are not aluminum. So what is the effect of the expansion then. Is it only the upper bearing shell effected?
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Aluminum block Main clearance [Re: jafr] #1612910
04/30/14 05:09 PM
04/30/14 05:09 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You didn't say what your main bore size is. If they left it on the small side of spec (and I bet they did) honing it to the large size of spec will help get you where you want to be.
