Re: 55 gallon e-85/98
[Re: MR_P_BODY]
#1612893
04/30/14 10:59 PM
04/30/14 10:59 PM
Posts: 4,071 Mo.
racerx
Mo.
All we can get at the pump here in Tennessee is E70. I've been mixing E98 with it to make E85. I only have enough E98 for a couple more trips to the track, so I'm thinking about rejetting the carb for E70 and see how that works. Mike, what are your thoughts on running on E70?
If your compression will handle it then just change your settings to adjust to E-70
So I guess you will jet down for this e-70?And is it still 10 degrees in the 1/8 and 20 degrees in the 1/4on the temp tune?
[Re: racerx]
#1612895
05/02/14 07:44 PM
05/02/14 07:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
? for the fellas that blend there own fuel out of e-98 what fuel grade do you all blend with regular ,midgrade ,premium?
Standard E-85 is blended with regular fuel.. on the 10* stuff... I never did it that way.. I jetted for the best MPH but it did work out close to 20* in the 1/4 but not right on
[Re: MR_P_BODY]
#1612896
05/02/14 10:25 PM
05/02/14 10:25 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Standard E-85 is blended with regular fuel.. on the 10* stuff... I never did it that way.. I jetted for the best MPH but it did work out close to 20* in the 1/4 but not right on [/quote Educate me on what you mean by 20* . I will be running 2-3110s on a crossram Hemi and I need a starting place on the jetting.
[Re: cudaman1969]
#1612897
05/03/14 01:03 AM
05/03/14 01:03 AM
Posts: 4,071 Mo.
racerx
Mo.
He's referring to 20 degree temp. increase in the 1/4
