Re: 55 gallon e-85/98 [Re: MR_P_BODY] #1612893
04/30/14 10:59 PM
04/30/14 10:59 PM
Mo.
racerx Online work OP
racerx  Online Work OP
Mo.
All we can get at the pump here in Tennessee is E70. I've been mixing E98 with it to make E85. I only have enough E98 for a couple more trips to the track, so I'm thinking about rejetting the carb for E70 and see how that works. Mike, what are your thoughts on running on E70?
If your compression will handle it then just change
your settings to adjust to E-70
So I guess you will jet down for this e-70?And is it still 10 degrees in the 1/8 and 20 degrees in the 1/4on the temp tune?
Re: 55 gallon e-85/98 [Re: racerx] #1612894
05/02/14 07:38 PM
05/02/14 07:38 PM
Mo.
Mo.
? for the fellas that blend there own fuel out of e-98 what fuel grade do you all blend with regular ,midgrade ,premium?
Re: 55 gallon e-85/98 [Re: racerx] #1612895
05/02/14 07:44 PM
05/02/14 07:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Standard E-85 is blended with regular fuel.. on the
10* stuff... I never did it that way.. I jetted for
the best MPH but it did work out close to 20* in the
1/4 but not right on
Re: 55 gallon e-85/98 [Re: MR_P_BODY] #1612896
05/02/14 10:25 PM
05/02/14 10:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
[/quote
Educate me on what you mean by 20* . I will be running 2-3110s on a crossram Hemi and I need a starting place on the jetting.
Re: 55 gallon e-85/98 [Re: cudaman1969] #1612897
05/03/14 01:03 AM
05/03/14 01:03 AM
Mo.
Mo.
[/quote
He's referring to 20 degree temp. increase in the 1/4
Re: 55 gallon e-85/98 [Re: racerx] #1612898
05/05/14 07:09 PM
05/05/14 07:09 PM
Mo.
Mo.
I found someone here selling e-98 for 257.00 a barrel, My understanding is that e-98 is cheaper than e-85 cause of the gas content am I wrong on this ?he sells the e-85,98 for the same price.
