Re: Ram 5.9 360 mag. timing issue
[Re: stateline]
#1612769
04/27/14 10:42 PM
04/27/14 10:42 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
Timing is controlled by the computer. What needs to be set is the sync signal, and that can be set using a more advanced scanner. Turning the distributor not using a scanner will result in poor running vehicle. The marks on the balncer don't really mean alot like an old school engine with a timing light.
Also, a worn timing chain and distributor drive bushing will make the sync signal be off. I would also look at your plugs/wires/cap and rotor. Look into replacing them if they have age on them. I use factory Champion plugs I get from the auto parts store, but I buy the tune up kit from Mopar. These are pretty basic motors that don't usually require alot other than normal maintance.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1612770
04/30/14 06:23 AM
04/30/14 06:23 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
If your idle is surging, then it may be time to do some simple maintenance.
clean the throttle body idle passage, clean/replace the idle control solenoid, and check for vacuum leaks -- particularly the plenum gasket on the bottom of the intake mainfold (remove the intake to do this)
IF you still have a surging idle after doing these, then look at going deeper and cleaning or replacing the other sensors.
having a scan tool like an MT2500 that allows you to read each sensor 'live' while the computer operates in closed loop, will allow you to see if any one sensor is causing the idle to bounce.
Couldn't hurt to replace the timing chain either, but that's going a bit deeper than 'routine maintenance'
**Photobucket sucks**
[Re: 70Cuda383]
#1612771
05/04/14 11:25 PM
05/04/14 11:25 PM
Posts: 1,294 Under the big sky
stateline
Under the big sky
Couldn't hurt to replace the timing chain either, but that's going a bit deeper than 'routine maintenance' [/quote
Thanks for the help, the idle isnt surging . after restarts some times , idle is a little rough , after it runs awhile it smooths out. the engine in it has 90k on it. I have it timed right. it will ping too. I wondered if a computor flash would help. it acts like the computor is slow getting the timing under control??
[Re: NITROUSN]
#1612773
05/05/14 01:39 AM
05/05/14 01:39 AM
Posts: 954 garnett kansas
rhad
garnett kansas
look thru the throttle body with a flashlight,oil in the intake means the plenum gasket is leaking,or,you have lots of blowby thru the pcv valve
my ladder of success is missing some rungs
[Re: rhad]
#1612774
05/05/14 01:55 AM
05/05/14 01:55 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
My first bet, plenum gasket. How many miles on the distributor on the 90k motor??
Leads to second bet, I had a LA 360 30 years ago that had unsteady idle. Guy put it on a scope at Precision Tune (Do they even exist anymore??), and graph showed the timing moving around at idle. Distributor shaft was worn and wobbling (bushing was okay). Replaced the distributor and all was well.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: 85_Ram_4speed]
#1612778
05/12/14 01:58 AM
05/12/14 01:58 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Did you check the intermediate shaft (gear wear) and bushing (shaft wear) when the dist was out? (jumpy timing)
The sync can be set without a tool.It only has to be in a 5 degree window.Align the rotor with the #1 on the cap.It should be the trailing edge of #1.If you miss it you will run very rough (or no start) and it will not get better.You can move the dist at idle and know immediately when it is out.
Leave the gun.......take the Cannoli's....Mike
