TTI x-pipe exhaust compatible with Gear Vendors OD??
#161247
12/04/08 08:41 PM
12/04/08 08:41 PM
Posts: 141 Milwaukee, WI
joflaig
Milwaukee, WI
I'm trying to determine if I need to mod my TTI x-pipe exhaust if I have the Gear Vendors over drive (Part #3DFS727A) installed on my 727. Anyone gone through this?
Here's what GV said:
"From the center of your yoke, measure down 4.25 inches from the centerline, this is where our oil sump sits."
I know I have to have the tunnel bumped out a bit, but the exhaust mods, if needed, might be time consuming and I can't picture them. Obviously, the loop will have to go.
Re: TTI x-pipe exhaust compatible with Gear Vendors OD??
[Re: joflaig]
#161249
12/04/08 09:53 PM
12/04/08 09:53 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Call them I think they have a display with a Gear Vendors overdrive and their exhaust system. I just don't remember if it was a 'X' or not.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: joflaig]
#161250
12/04/08 10:59 PM
12/04/08 10:59 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I like the foam wrapping on the top of your loop. The TTI website has some info about this. I believe they said it won't work with the 3" x-pipe.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: joflaig]
#161251
12/04/08 11:24 PM
12/04/08 11:24 PM
Posts: 8,495 Candler,NC / Myrtle Beach, SC
JDMopar
Just looking at it, I don't think it's gonna fit. I put my GV in my Challenger that had an X pipe on it, and the X pipe had to go. Mine wasn't a TTI pipe, but it was in almost the same spot as yours. I hated to do it, but I had to mine off, and take it to the exhaust shop when I got the GV in. I didn't like the way the X pipe looked when we mocked it up behind the tailshaft/yoke on the GV, so I just said the heck with it. It's not a super high HP car anyways, but I do miss the sound
[Re: screamindriver]
#161253
12/06/08 11:51 AM
12/06/08 11:51 AM
joflaig
Milwaukee, WI
Sorry but your loop and the X pipe will have to go...It's crossing right where the unit will be placed...I had the normal TTI H pipe and ended up replacing it with the new TTI H pipe for the GV unit...I snagged on of the first units they made and it fit around the GV unit perfectly..
Yeah, I see TTI is now offering an H-pipe to work with the GV unit. What does the h-pipe sound like compared to the x-pipe? I had understood the x-pipe was better for performance. Is there any way modify the x-pipe to make it work?
Thanks!
#161255
12/06/08 02:01 PM
12/06/08 02:01 PM
joflaig
Milwaukee, WI
The H pipe is a little louder than the X pipe... I first tried to modify the original H pipe on the car but it hung down too low... It got the car to the local exhaust shop where they bent{non-mandrel} new pipes for me and I added the cross tube myself but I felt a drop in power right away across the board when leaving the shop...I actually called TTI and they said they were working on the GV piece so I waited...It's amazing the difference on a good mandrel bent system... ..You could try to modify the X pipe if you snagged a few mandrel bends and some pipe but it's tricky with the angles of the headers in relationship to the cross tubes... If you go that route make sure you let us know how you made out...
Sounds like I'll call TTI.
[Re: 500Stroker]
#161257
12/06/08 08:56 PM
12/06/08 08:56 PM
joflaig
Milwaukee, WI
I had to ditch my TTI H pipe when I installed the GV. Added a summit H kit further back. This pic will give you an idea how long the trans GV combo is. You not only add the GV you also replace the tailshaft with a much longer adapter shaft that the guy in the middle has a hand on.
Geez, I see what you mean. At least TTI makes a H-pipe now to work with the GV unit. I'm just not sure about the sound and performance changes.
[Re: joflaig]
#161258
12/07/08 04:45 PM
12/07/08 04:45 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
Not to hijack but . . . Even with the exhaust issues aside, how do you guys like your gear vendors? Any vibration issues? Would you do it again, or go 5 speed?
I'm Gumby dammit!
[Re: 500Stroker]
#161259
12/07/08 08:02 PM
12/07/08 08:02 PM
joflaig
Milwaukee, WI
I wonder on a b body where you put the drive shaft safty loop on with the GV ID unit installed?
If the driveshaft is a 1 foot shorter, there would ne cross member to use, so I guess it could be bolted or welded to the floor pan itself, right? What are the regs?
[Re: jbc426]
#161260
12/11/08 10:31 PM
12/11/08 10:31 PM
Posts: 3,488 Annapolis, MD, USA
Vert
Annapolis, MD, USA
I don't know about the GV unit. But I can't fit the USCT loop with a 3in TTi X-pipe. Its tight!
[Re: Gumbydammit]
#161261
12/12/08 12:42 AM
12/12/08 12:42 AM
Posts: 2,025 Bucks County, PA
500Stroker
Bucks County, PA
Best improvement I ever made to the car. 35K trouble free miles so far. No vibrations or problems.
