Help..! What year crew cabs will interchange ? #1611915
04/25/14 01:55 PM
04/25/14 01:55 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hello, I have a 1985 Dodge 1 ton dual rear wheel crew cab truck that has a rust issue in the front part of the roof. I want to find out what year crew cabs will interchange??? I am thinking 1972-74 has a smaller rear window and 1975-80 has a different dash and I don't know if my dash in my 1985 Crew cab will bolt right in the same or not???
Looking for a rust free cab.. any help would be appreciated.
glr7069@ptd.net
Pa
Re: Help..! What year crew cabs will interchange ? [Re: GLR] #1611916
04/25/14 06:10 PM
04/25/14 06:10 PM
Wis., USA
Bob_Fromm Offline
Bob_Fromm  Offline
Wis., USA
72-80 Cabs are the same and 81-93 are the same. The early models didn't have the roof rust out issue as the 81-93 do. As far as interchange there are body line differences but you can mix and match. Scratch'n who is a Dodge truck guru on Moparts has a good post on here on how he fixed his '81 up style roof issue. I was impressed...
Good luck!
Re: Help..! What year crew cabs will interchange ? [Re: Bob_Fromm] #1611917
04/25/14 06:46 PM
04/25/14 06:46 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
72-85 Crewcabs are all the same. the bulkhead hole is different for the wiring and the hvac I believe is different (both mentioned pertain to 72-80 vs 81-85) The rest is the Same. the Standard cabs are what changed as in the roof skin was redone and the above mentioned. Clubcabs follow the same criteria as the Crewcabs
Re: Help..! What year crew cabs will interchange ? [Re: 76dodgeboy] #1611918
04/25/14 06:49 PM
04/25/14 06:49 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
ALL the body lines are in the Front doors renders and box Not the cabs. 70s had rust in the roofs aswell. The Cabs in any configuration Do Not have a body line.
Re: Help..! What year crew cabs will interchange ? [Re: 76dodgeboy] #1611919
04/25/14 07:09 PM
04/25/14 07:09 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thank you, I think I would rather stay with an 81-85 cab so I can use all of my HVAC stuff
Re: Help..! What year crew cabs will interchange ? [Re: GLR] #1611920
04/25/14 09:09 PM
04/25/14 09:09 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Roof rust is an issue in all of them as the factory didn't coat the metal on the inner side of either the outer or inner roof skin on any of them
Look for evidence of Ziebart or Rusty Jones treated cabs The dealer some times sprayed the inside of the roofs on some to kill water leaks
If you find a good one spray the insides of the roof before you put it on the truck so you can turn it & use gravity to your advantage
You're limited to 81-85 cab due to not only the HVAC but the steering column mounting changed in 79 also
Re: Help..! What year crew cabs will interchange ? [Re: BulletBob] #1611921
04/26/14 08:40 PM
04/26/14 08:40 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What Changed on the Steering column mounting? Pretty sire my 80 mounts the same as my 76 did. looks like Ill be checking tomorrow
Re: Help..! What year crew cabs will interchange ? [Re: 76dodgeboy] #1611922
04/26/14 08:57 PM
04/26/14 08:57 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
I'd like to know what changed also.
Re: Help..! What year crew cabs will interchange ? [Re: 77ProStreet] #1611923
04/27/14 01:50 PM
04/27/14 01:50 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The mounting plate changed under the dash I found that out when I went to put a 79 tilt column in my 77 CrewCab 78 tilt column is a one year only column look it up in the factory parts book like I have
The hole where it passes through the firewall is the same I have a dozen or so columns I can take the pics of to show what I'm talking about
I restore & sell the tilt columns for 78-80 trucks I know what fits & what don't
Re: Help..! What year crew cabs will interchange ? [Re: BulletBob] #1611924
04/27/14 03:30 PM
04/27/14 03:30 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The column on the right is from a 79 that a customer sent me recently to rebuild the one on the left a 78' only tilt column
Notice the difference in the mounting as well as the location of it
Re: Help..! What year crew cabs will interchange ? [Re: BulletBob] #1611925
05/01/14 03:01 AM
05/01/14 03:01 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
I have a 84 and a 85 I would sell, complete trucks "running when parked" neither has factory air. PM or email at shinnerytree at yahoo.com. They are about twenty miles north of Abilene, Texas. Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: Help..! What year crew cabs will interchange ? [Re: 76dodgeboy] #1611926
05/02/14 11:27 AM
05/02/14 11:27 AM
Canada
demon Offline
demon  Offline
Canada
There is no difference in the steering column mount.
I installed a 1992 column in my 1979 crew cab when I did my Cummins conversion and it was a 100% bolt in.
I've had dozens of these trucks apart over the last 30 years. The only real change in the crew cabs between 72-85 was the heater opening in the firewall changed in 1981.
All doors, dashes, glasses etc will interchange.
Someone mentioned earlier about smaller back windows in the earlier trucks.
Yes, the glass was smaller but the cab window opening never changed, just the glass itself and the weatherstrip. It was just the shape of the weatherstrip changed in he mid 70's to allow a slightly larger glass to be used.
Re: Help..! What year crew cabs will interchange ? [Re: demon] #1611927
05/03/14 04:42 AM
05/03/14 04:42 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I put the sliding window from a 87' in my 77'
Re: Help..! What year crew cabs will interchange ? [Re: BulletBob] #1611928
05/03/14 02:38 PM
05/03/14 02:38 PM
Canada
demon Offline
demon  Offline
Canada
Yes all the glass will interchange. Just use the weather strip that matches the glass and it s all good.
One thing you need to watch for when doing any cab swap on the 72-93 Lifestyle series trucks is the transmission floor tunnel size. There were a few variations. Small round hump on 2wd automatics, large square hump on 4 speeds and all 4wd's. a small hump can be cut out and have the big bolt in hump installed but its a little trickier going the other way.
Re: Help..! What year crew cabs will interchange ? [Re: demon] #1611929
05/03/14 07:46 PM
05/03/14 07:46 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I'm putting a 84 firewall & floor section in mine It's from a RamCharger & I'll have a tunnel that fits my 518 a whole lot better & the A/C parts will fit together well with the 92-93 Magnum stuff easier & look like it came that way
The factory buckets & console don't hurt either
