Help..! What year crew cabs will interchange ?
#1611915
04/25/14 01:55 PM
04/25/14 01:55 PM
Posts: 2,506 Northern Pa
GLR
Northern Pa
Hello, I have a 1985 Dodge 1 ton dual rear wheel crew cab truck that has a rust issue in the front part of the roof. I want to find out what year crew cabs will interchange??? I am thinking 1972-74 has a smaller rear window and 1975-80 has a different dash and I don't know if my dash in my 1985 Crew cab will bolt right in the same or not??? Looking for a rust free cab.. any help would be appreciated. glr7069@ptd.netPa
Re: Help..! What year crew cabs will interchange ?
[Re: BulletBob]
#1611925
05/01/14 03:01 AM
05/01/14 03:01 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
I have a 84 and a 85 I would sell, complete trucks "running when parked" neither has factory air. PM or email at shinnerytree at yahoo.com. They are about twenty miles north of Abilene, Texas. Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
[Re: 76dodgeboy]
#1611926
05/02/14 11:27 AM
05/02/14 11:27 AM
Posts: 1,179 Canada
demon
Canada
There is no difference in the steering column mount. I installed a 1992 column in my 1979 crew cab when I did my Cummins conversion and it was a 100% bolt in. I've had dozens of these trucks apart over the last 30 years. The only real change in the crew cabs between 72-85 was the heater opening in the firewall changed in 1981. All doors, dashes, glasses etc will interchange. Someone mentioned earlier about smaller back windows in the earlier trucks. Yes, the glass was smaller but the cab window opening never changed, just the glass itself and the weatherstrip. It was just the shape of the weatherstrip changed in he mid 70's to allow a slightly larger glass to be used.
[Re: BulletBob]
#1611928
05/03/14 02:38 PM
05/03/14 02:38 PM
Posts: 1,179 Canada
demon
Canada
I put the sliding window from a 87' in my 77'
Yes all the glass will interchange. Just use the weather strip that matches the glass and it s all good. One thing you need to watch for when doing any cab swap on the 72-93 Lifestyle series trucks is the transmission floor tunnel size. There were a few variations. Small round hump on 2wd automatics, large square hump on 4 speeds and all 4wd's. a small hump can be cut out and have the big bolt in hump installed but its a little trickier going the other way.
