Valley pan and gaskets?? #1611473
04/24/14 12:18 PM
04/24/14 12:18 PM
Penna
70satelliteguy Offline OP
Penna
Is it necessary to use gaskets with the regular tin valley pan? Should I use just one or 2?
Thanks Mike
Re: Valley pan and gaskets?? [Re: 70satelliteguy] #1611474
04/24/14 12:28 PM
04/24/14 12:28 PM
People have went both ways & have had success (& failures) either way with or without and 1 or 2. A guy on here "superperformance) iirc sells thin .015" paper gaskets which are my choice (on both sides) with Permatex "high tack" the red stuff in the spray can to glue em on, #99MA and Permatex #1 in the toothpaste like tube around the 8 port openings on the pan on both sides to seal the ports. A thin wide even swath. First mockup the pan/intake dry & check the height of the bolt holes as with OE deck height variation/head/deck milling/many thickness available for head gaskets you could be anywhere regarding that fitment. The felpro paper gaskets are .030" iirc maybe thicker
Re: Valley pan and gaskets?? [Re: 70satelliteguy] #1611475
04/24/14 12:48 PM
04/24/14 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I like to use one paper on each bank as insurance.
Re: Valley pan and gaskets?? [Re: JohnRR] #1611476
04/24/14 01:14 PM
04/24/14 01:14 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I've always used the thin .015" gaskets.....especially with the aluminum intakes. I usually just glue them on the manifold side of the tray and use some sealer on the head side around the port openings. NEVER had any issues with vacuum leaks.
Superformance makes them now. The Mopar number was 3514186.
Re: Valley pan and gaskets?? [Re: superwrench] #1611477
04/24/14 02:29 PM
04/24/14 02:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Since the 60s Ive never used papers.Never a problem.My 440 now has aluminum intake and heads.The sons 413 has iron and aluminum same thing.Back in the day the tins were even reused as they were pricey.I remember buying one in 67 and it was over 20 bucks.Lots of $$$ back then for a gasket.Rocky
Chrysler Firepower
Re: Valley pan and gaskets?? [Re: 70satelliteguy] #1611478
04/24/14 04:30 PM
04/24/14 04:30 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
It is not "necessary" to use any gasket facing pieces with the stamped valley pan.
My thought is these are mainly used as a "shim" if you will, to properly align and fill a gap between the intake ports in the head with the ports on the manifold depending on how much material that may have been removed from block decking or cylinder head milling.
They can however provide additional sealing characteristics due to the material composition.
Superformance Products now offers these gaskets made from Interface Solutions NI-2085 material, better than anything available on the market for this application part #6404.
Re: Valley pan and gaskets?? [Re: roadhazard] #1611479
04/24/14 10:48 PM
04/24/14 10:48 PM
superwrench Offline
superwrench  Offline
Superformance Products now offers these gaskets made from Interface Solutions NI-2085, better than anything available on the market for this application.
THAT is good to know !! Thanks.
Re: Valley pan and gaskets?? [Re: roadhazard] #1611480
07/29/14 07:20 PM
07/29/14 07:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Back to the top ...
Greg , what was the material you used to make them from ? I have some that are gray paper , came vac packaged 4 to a set on white cardboard , can't remember if these were from you ??
Re: Valley pan and gaskets?? [Re: JohnRR] #1611481
07/29/14 11:36 PM
07/29/14 11:36 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Back to the top ...
John originally we were making them from Interface N-8094 and have recently upgraded the material to Interface NI-2085 for better long term durability.
The N-8094 is a gray fiber material, kind of standard middle of the road. The NI-2085 is a charcoal/black material and is very flexible.
The gasket is also marked with those numbers.
