Engine won't turn over #1611118
04/23/14 06:36 PM
04/23/14 06:36 PM
Tri Cities TN area
Hailtheleaf538 Offline OP
Never Misses A Coffee Break
Tri Cities TN area
Got a question for you guys out there: I go to start the 340 up, it won't turn over in park at all. I had this problem last year when driving it. Howevrr, I would put it in neutral and it would start right up. I'm assuming it's probably a simple fix, but I could be wrong. Thought maybe the neutral safety switch? Any suggestions greatly appreciated.
Organized Labor: The people that brought you the weekend. If you can't grasp the meaning of the phrase "tongue in cheek", don't respond. 1970 H code Swinger, Top Banana 2012 Liberty Jet 4x4 True Blue Pearl
Re: Engine won't turn over [Re: Hailtheleaf538] #1611119
04/23/14 07:15 PM
04/23/14 07:15 PM
Central TX
roe Offline
roe  Offline
Central TX
That's where I would look, NSS. Also if it's an auto then make sure the gear selector is solidly in park.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Engine won't turn over [Re: roe] #1611120
04/23/14 07:28 PM
04/23/14 07:28 PM
Tri Cities TN area
Tri Cities TN area
Thank you.
Re: Engine won't turn over [Re: Hailtheleaf538] #1611121
04/23/14 07:45 PM
04/23/14 07:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Yes, it sounds like the shift linkage is a little out of adjustment.
Re: Engine won't turn over [Re: stumpy] #1611122
04/24/14 11:59 AM
04/24/14 11:59 AM
scratchnfotraction Offline
it is better to start it in N for the trans to start pumping fluid and fill TC.
but try holding up on shift lever while starting to see if it will hit in park.
slightly worn/mis-adjusted shift linkage is what it sounds like to me as it starts in N with no issues..so in park the rooster comb is not far enuff to make the conection.
Re: Engine won't turn over [Re: scratchnfotraction] #1611123
04/24/14 12:08 PM
04/24/14 12:08 PM
& I would dig in & find where the misadjustment is since it might continue to deteriorate to where one day it wont start even in neutral & that might happen at the most inopportune time (Murphys law) (hot date or a getaway driver etc)
