Re: 1969 Dart GTS Grill and headlight bezel question
[Re: mopfried]
#1610870
04/23/14 09:56 AM
04/23/14 09:56 AM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
No matter what you see ALL 69 GTS's were blacked out EXCEPT for the two bands second from the top and bottom and around the center of the grille. The bezels also followed the same pattern. I will find a pic and put it on later. ![](/ubbthreads/images/graemlins/wave.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1610873
04/23/14 09:58 PM
04/23/14 09:58 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Is the middle horizontal bar and the flat surface at the bottom of the grill supposed to be Argent, or natural? If Argent, how does that transition into the bezels?? Mine are natural now, but the grill and bezel had been stripped and incorrectly painted when I bought the car.
Rhino, that green car you referenced has red hood vents, never seen that before. Is that a big block thing, or just incorrect?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Rhinodart]
#1610875
04/23/14 11:58 PM
04/23/14 11:58 PM
GO_Fish
Maryland
Sure! a picture or 2 of how the Argent transitions into the bezel would be extremely helpful. It will bring my GTS another notch closer to OE glory!
Scott B.
[Re: Rhinodart]
#1610877
05/01/14 11:51 PM
05/01/14 11:51 PM
Posts: 738 Columbus Ohio
mopfried
Columbus Ohio
Yep, the red in the inserts is incorrect, but looks pretty cool! The center of the grille and the bottom are argent. I can take a close-up pic for reference if you need it.
What would be a good source of black and argent paint for redoing my gts Grill?
[Re: mopfried]
#1610878
05/02/14 04:35 AM
05/02/14 04:35 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
Krylon Dull Aluminum #1403
Krylon OSHA black #1770 (industrial line)
[Re: autoxcuda]
#1610881
05/06/14 09:44 AM
05/06/14 09:44 AM
mopfried
Columbus Ohio
I found O'Reilly carries the Krylon dull aluminum #1403 and MSC has OSHA black 1770... but it is listed as gloss black? It that correct?
