Re: Building 572 hemi. Is aluminum block worth the $$? [Re: wyoming] #1609985
04/21/14 11:08 PM
04/21/14 11:08 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
They look pretty darn good, hope they can stick around awhile, how long have they been in the block biz?
Not sure exactly. They don't cast the blocks themselves. They are cast in southern California. He said who cast them but I cannot remember who it was.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: wyoming] #1609986
04/21/14 11:17 PM
04/21/14 11:17 PM
Think I may sell my mega block and get myself one of these aluminum blocks. My block is sitting with Dan the man at Performance Only so if anyone has interest you can pm me, and no this is not an add thank you.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609987
04/21/14 11:43 PM
04/21/14 11:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
Was it Buddy Boy in the L.A., Long Beach area of the L.A. basin? If so they use to be the Alcoa foundry back in the day when all the Dept. Of Defense contracts where so active in SO CA
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Cab_Burge] #1609988
04/21/14 11:44 PM
04/21/14 11:44 PM
Oakley CA
Oakley CA
Was it Buddy Boy in the L.A. Basin? If so they use to be the Alcoa foundry back in the day when all the Dept. Of Defense contracts where so active in SO CA
I just sent him an email asking who it was. All I remember was someone in SoCal that has been doing it for 30+ years.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Sammy] #1609989
04/22/14 09:17 AM
04/22/14 09:17 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
After seeing these blocks first hand and speaking to them at the MATS I would not hesitate to buy one of these. In fact I will be ordering one here soon.
http://www.hpperformancellc.com/
FWIW I have a KB and World aluminum block here and the next build will be with an HP block.
Wow, They look nice. Do they have any in stock. Do they have raised cam blocks too?
yes, Raised 55mm roller bearing
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609990
04/22/14 10:52 AM
04/22/14 10:52 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Starting a 572 hemi build. Was wondering what people's opinions are on if the aluminum block is worth the $$ over the iron block?
Car will be naturally aspirated , mostly street car.
. Don't forget, resale value. If you ever find yourself in a situation where you need to sell you are pretty much guaranteed to get your $ back.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Bill MeLater] #1609991
04/22/14 02:13 PM
04/22/14 02:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ahhh, but Mopar people only hunt for bargains....So if a Hemi isn't a bargain, they just can't crack the wallet open that far....
I had two people want my running Hemi, but they wanted for the price of a wedge....Ain't happening.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609992
04/22/14 04:44 PM
04/22/14 04:44 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
For me and my car yes it was worth it. My car weighed 2512 with me and a indy headed small block and a 727. I switched to a B1 headed Indy Maxx motor and a glide and the car weighs 2500 lbs exactly now with me in it.
Had I used a World Iron block my car would be 200 lbs heavier and all on the nose!
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: wyoming] #1609993
04/23/14 10:29 AM
04/23/14 10:29 AM
dogdays Offline
dogdays  Offline
HP Performance blocks are cast at the Buddy Bar foundry California. According to the article I read, they used to cast all Edelbrock's stuff until E built its own foundry. They still do all the Weiand and Holley intakes and stuff.
R.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: dogdays] #1609994
04/23/14 10:32 AM
04/23/14 10:32 AM
an8sec70cuda Offline
When I built my hemi, there were no iron blocks available and KB or Indy were the only 2 choices. I went w/ KB and couldn't be happier. Should be the last block I'll ever need to buy...repairable if it blows up, mess up a bore just install a new sleeve, etc. Not to mention saving a little weight up front.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: an8sec70cuda] #1609995
04/23/14 02:33 PM
04/23/14 02:33 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
A LITTLE WEIGHT?!?!?!?!
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: jim sciortino] #1609996
04/23/14 02:40 PM
04/23/14 02:40 PM
Well, my car's a sled so yeah, it is a little to me, lol. I didn't really lose any weight when I put the hemi in...turns out my all aluminum hemi weighs nearly the same as the iron block/aluminum head 440 it replaced.
CHIP
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: an8sec70cuda] #1609997
04/23/14 06:36 PM
04/23/14 06:36 PM
Trumbull,CT.
Trumbull,CT.
Now imagine an aftermarket iron HEMI block.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: jim sciortino] #1609998
04/23/14 06:51 PM
04/23/14 06:51 PM
I have one of those too...an iron World block. It's on the engine stand now and man is that thing heavy! It was 4.25" bore when I got it...decided to take it out to 4.5" bore. One reason was to take some weight out of it, lol.
CHIP
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: an8sec70cuda] #1609999
04/24/14 12:55 AM
04/24/14 12:55 AM
Trumbull,CT.
Trumbull,CT.
Every little bit helps.
