Building 572 hemi. Is aluminum block worth the $$? #1609965
04/20/14 07:08 PM
04/20/14 07:08 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Starting a 572 hemi build. Was wondering what people's opinions are on if the aluminum block is worth the $$ over the iron block?
Car will be naturally aspirated , mostly street car.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609966
04/20/14 07:26 PM
04/20/14 07:26 PM
Sleeves insure good thick cylinders and all even--Mega Blocks are good when they are good but some keep you from boring bigger --Mains are way stronger in the KB, Indy style blocks vs. Mega blocks--the cross bolts there are not that big a deal--I have seen plenty of cap walk on Mega blocks--You can fix an aluminum block but busted iron is usually candidate for coffee table art My take is a 572 on the street is like driving the Zamboni at the ice rink
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609967
04/20/14 08:00 PM
04/20/14 08:00 PM
The differences in the expansion rate of the aluminum block and the steel or iron sleeves makes me not want to run a aluminum block on a N/A motor, race or street, I hate engines that smoke from oil I'm sure now with all the LS3 and up LS Chevy motors out there that have aluminum blocks that you can make a aluminum block motor not smoke from oil consumption But I do know you can make more power and have a longer ring seal life with iron blocks compared to aluminum street blocks It's your choice
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609968
04/20/14 11:24 PM
04/20/14 11:24 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
The Short answer.
I would do it again.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Hemi Allstate] #1609969
04/21/14 12:08 AM
04/21/14 12:08 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes....I would have one if I had saved a little more. I have a iron one instead. Would love an aluminum one. Any after market block you buy will give you some trouble, get it thru a dealer who will make it right if something is off.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609970
04/21/14 12:19 AM
04/21/14 12:19 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
NOPE, you dont Need one. The Iron block is fine for you.
But, If your Funds are fine, and it wont hurt you. The aluminum block will be quite a cool Factor for you. But you dont need it. Not for a street car.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Dragula] #1609971
04/21/14 12:52 AM
04/21/14 12:52 AM
Oakley CA
Oakley CA
Any recommendations for a good dealer? I asked a while back but didn't really get any responses.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Sport440] #1609972
04/21/14 12:55 AM
04/21/14 12:55 AM
dogdays Offline
dogdays  Offline
Difference in expansion rate between iron sleeves and aluminum block? That's a non-issue. Here's why: Iron sleeves have a smaller coefficient of linear expansion than the aluminum block, but they are closer to the fire. The block for the most part is a little hotter than the coolant, and the sleeves are hotter than the block. Those temperature differentials have to be there for the heat to flow out of the cylinder.
How would an iron cylinder that didn't expand as much as an aluminum block cause oil burning? That's hard for me to see. The reason that we have to run several thousandths of clearance between the aluminum pistons and the iron blocks is because the piston expands that much more. So unless you have an iron piston running in an aluminum bore, the hotter the engine gets the less clearance between piston and cylinder, meaning there is less chance of oil escaping.
Also, think of all the millions of aluminum block engines that have to pass emissions for 100,000 miles. If they tended to become oil burners they could never be certified, never be sold at all in the USA.
So here's the real issue - Money and weight. A stock 440 block weighs something like 220lb. A cast iron aftermarket block, at least the World Products cast ones, weigh 320 lb. An aluminum block may weigh 120 lb. So going from the iron to the aluminum aftermarket block will take about 200# off the front end of your car. That's quite a bit less mass to try to steer, accelerate and brake. If you can afford it, it's the way to go in my book. Add in the repairability of aluminum over cast iron and it's quite an advantage.
Sure you don't NEED it, but most of us don't NEED more than Slant 6 type power to get our cars from pt. A to pt. B, either.
R.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: dogdays] #1609973
04/21/14 01:34 AM
04/21/14 01:34 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I've had iron and aluminum in street cars and would NEVER consider an iron block again......especially the iron blocks available for big blocks and HEMIs.
The stock 440 block in my 499ci Indy 440-1 engine weighed about 240#. An iron aftermarket block is well over 300# and they aren't exactly state of the art.
My 526ci HEMI uses a KB water block without issue and it came in a about 140# w/caps. It is a far better choice than the currently available iron blocks and is repairable in most instances should the unforeseen occur.
With current piston and ring technology, along with vac pumps, the sealing issues are not what they were years ago. As long as no high-end manufacturer of iron, or CG blocks is willing to take the plunge into the MOPAR market and release a cutting edge piece that doesn't weigh slightly less than the anchor on the Titanic, aluminum is the way to go and well worth the money.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: jim sciortino] #1609974
04/21/14 09:15 AM
04/21/14 09:15 AM
gregsdart Online content
gregsdart  Online Content
If you like acceleration, then aluminum! That 100+ lbs off the nose is going to be worth it, even on the street where traction is more limited. The 1500 or so you save will soon be forgotten when you wish (like me ) you had gone aluminum!
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609975
04/21/14 11:16 AM
04/21/14 11:16 AM
Dragula Offline
Dragula  Offline
Actually your from Ca, and KB is closest if you can allow for their lead time. They are probably the only one I would go direct with, but they not the fastest at filling your order. Great to deal with and will always make it right.
-Keith Black Racing Engines
If your looking at buying an Indy Hemi block and getting started a lot sooner, then I would recomend one of the following dealers:
-Bob George Racing
-For Hemis Only
-Ray Barton Racing Engines
-Muscle Motors
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609976
04/21/14 02:42 PM
04/21/14 02:42 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Bob Mazzolini. he is a CA racer so you should be able to pick up your block instead of getting it shipped. Buying an Indy block from him would be the only way, and you do not have to deal with Indy yourself.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Airwoofer] #1609977
04/21/14 03:37 PM
04/21/14 03:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
After seeing these blocks first hand and speaking to them at the MATS I would not hesitate to buy one of these. In fact I will be ordering one here soon.
http://www.hpperformancellc.com/
FWIW I have a KB and World aluminum block here and the next build will be with an HP block.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Al_Alguire] #1609978
04/21/14 03:56 PM
04/21/14 03:56 PM
Oakley CA
Oakley CA
Want to sell one of them?
Thanks for the link to the HP site. Never knew about them. Time for some homework.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: 69charger440_6pa] #1609979
04/21/14 03:58 PM
04/21/14 03:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well the KB block in under my B1MC motor and the World block in under my Predator motor. But as they say everything is for sale
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Al_Alguire] #1609980
04/21/14 08:21 PM
04/21/14 08:21 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Wow, They look nice. Do they have any in stock. Do they have raised cam blocks too?
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Sammy] #1609981
04/21/14 09:10 PM
04/21/14 09:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
STD cam, Raised cam, big cam journal. pushrod oil, etc they can pretty much do whatever you want. Looks like very nice pieces in person. They have WAY more cylinder wall thickness than Indy for sure. Saw a cut away version and look much better than the indy or world stuff as well. Plus they incorporate some other cool features. They have a short lead time for traditional type stuff, believe they told me 2-3 weeks but don't quote me on that.
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Al_Alguire] #1609982
04/21/14 09:26 PM
04/21/14 09:26 PM
Oakley CA
Oakley CA
I talked to HP today and they said turn around was a couple weeks. They keep blocks on hand and finish machine once ordered..... What a concept.
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: Al_Alguire] #1609983
04/21/14 09:32 PM
04/21/14 09:32 PM
Trumbull,CT.
Trumbull,CT.
Good to know...
Re: Building 572 hemi. Is aluminum block worth the $$? [Re: jim sciortino] #1609984
04/21/14 10:46 PM
04/21/14 10:46 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
They look pretty darn good, hope they can stick around awhile, how long have they been in the block biz?
