'70 RoadRunner Body Line Question #1609580
04/19/14 07:28 PM
04/19/14 07:28 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Hey guys, I'm using AMD quarters and have a question about how the area behind the scoop flows rearward into the rest of the panel. There's a definite hump and I'm not sure if it's supposed to be there or not. Both quarters are replaced and both have it. I don't think it'll look right in paint but will seem to need quite a bit of filler to make it a smooth transition. Can someone here with a car with oem quarters tell me which is correct? Smooth front to rear or leave that hump, wave, or whatever the hell it is? Thanks everyone. Yeah I know, I should have looked while I was in Vegas.. or Spring Fling. This wasn't even on my mind then.
Re: '70 RoadRunner Body Line Question [Re: MCTPhoenix] #1609581
04/19/14 07:29 PM
04/19/14 07:29 PM
Phoenix, AZ
Phoenix, AZ
Another...
Re: '70 RoadRunner Body Line Question [Re: MCTPhoenix] #1609582
04/19/14 08:03 PM
04/19/14 08:03 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
I used amd on my 70 gtx an I just left that low but blocked it so no riple look good to me. here a pic hard to see.
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: '70 RoadRunner Body Line Question [Re: 1969gtx] #1609583
04/22/14 12:11 AM
04/22/14 12:11 AM
Phoenix, AZ
Phoenix, AZ
Thanks for posting, looks like I'll fill the area then block smooth.
