Hey guys, I'm using AMD quarters and have a question about how the area behind the scoop flows rearward into the rest of the panel. There's a definite hump and I'm not sure if it's supposed to be there or not. Both quarters are replaced and both have it. I don't think it'll look right in paint but will seem to need quite a bit of filler to make it a smooth transition. Can someone here with a car with oem quarters tell me which is correct? Smooth front to rear or leave that hump, wave, or whatever the hell it is? Thanks everyone. Yeah I know, I should have looked while I was in Vegas.. or Spring Fling. This wasn't even on my mind then.
