Ok is this going to be a problem child ? #1609553
04/19/14 06:29 PM
04/19/14 06:29 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
What I got with the combo I have is 14.5 compression. stock block-494ci eddy/mopar heads 72.4cc
Diamond pistons 4.355 bore 14cc domes .015 in the hole
4.15 stroke eagle crank-6.760 eagle rods-going to use fel-pro 1105 gaskets .051 thick. does have billet steel main caps. no fill. Tell me what you think ? Thanks Jamie
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609554
04/19/14 06:48 PM
04/19/14 06:48 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Forgot E-85 fuel
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609555
04/19/14 07:47 PM
04/19/14 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Jamie... whats your cranking pressure... but I dont
see any issue with the E-85
Re: Ok is this going to be a problem child ? [Re: MR_P_BODY] #1609556
04/19/14 07:49 PM
04/19/14 07:49 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I don't know yet mike. it is not all together. do you think it would live with that much compression ?
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609557
04/19/14 07:56 PM
04/19/14 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its all dependent on your cam.. when the intake closes
but I'm at 14.1:1 and not problem at all
Re: Ok is this going to be a problem child ? [Re: MR_P_BODY] #1609558
04/19/14 08:05 PM
04/19/14 08:05 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Ok how about you or anyone else recheck my math and see if you come up with the same numbers.
I have not bought a cam yet .So I should be looking for what ? one that would kill some of the cranking compression ?
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609559
04/19/14 08:36 PM
04/19/14 08:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
As you know the larger the duration the lower the
pressure will be... what do you intend the rpm to be
Re: Ok is this going to be a problem child ? [Re: MR_P_BODY] #1609560
04/19/14 08:55 PM
04/19/14 08:55 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
was shifting the car at 6000 and thought the traps at 6200
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609561
04/19/14 09:15 PM
04/19/14 09:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will assume this engine is gonna make more power
than the last one.. if so you will most likely go a
bit higher in the revs.... so what kind of duration
are you thinking
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609562
04/19/14 09:21 PM
04/19/14 09:21 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Jamie
I am guessing you will be shifting at 6800 and running low 10's now
Re: Ok is this going to be a problem child ? [Re: MR_P_BODY] #1609563
04/19/14 09:26 PM
04/19/14 09:26 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
are you thinking
277 @ .050 would work, hint, hint.
Keith
Re: Ok is this going to be a problem child ? [Re: Dunnuck Racing] #1609564
04/19/14 10:03 PM
04/19/14 10:03 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Ok lol I do not ! will not run it that hard. 10.90 is just fine .in fact I thought I would shift this lower..be easy on it .live awhile
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609565
04/19/14 10:18 PM
04/19/14 10:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If that`s the case then why the high comp. Seems a waste to go 10.90............you can do that w/a basic 440 build.
Re: Ok is this going to be a problem child ? [Re: Thumperdart] #1609566
04/19/14 10:23 PM
04/19/14 10:23 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
I did't mean for this to happen. I got a good deal on this short block. so I bought it. He told me it had 12.5 to 1 with his 75cc heads. LOL wrong ! and it had small domes on it. so now I am try to do the best I can with what I got.
Re: Ok is this going to be a problem child ? [Re: Thumperdart] #1609567
04/19/14 10:24 PM
04/19/14 10:24 PM
dogdays Offline
dogdays  Offline
How about because it's easier to make power with compression, and E85 supports some pretty high compression ratios.
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609568
04/19/14 10:56 PM
04/19/14 10:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You wouldnt be running it much harder than your old
engine... a few revs wont hurt that(not unless its
got stock rods)... but if you have aftermarket decent
rods then I wouldnt worry at all even if you went to
6800.... hell Jamie... you sound like you want to
idle to the finish line... LOL
Re: Ok is this going to be a problem child ? [Re: MR_P_BODY] #1609569
04/19/14 11:30 PM
04/19/14 11:30 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
shift at 2500 and coast across the line LOL
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609570
04/19/14 11:33 PM
04/19/14 11:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You have that high compression AND too much quench (.065"). How much CR can E85 support?
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609571
04/19/14 11:41 PM
04/19/14 11:41 PM
You have two choices, use it or not use it I would make sure it was alittle on the rich side with the E85 and not to much timing and go bracket racing Who did or who is going to do your E85 Carb? I had AJ Castilini(SP?) do mine, it is real sensitive on the dyno to jetting, one jet size either way would make it lose power BTW, E85 and bracket racing are made foe each other, hardly any change in ET from early morning to late afternoon Don't tell anyone else that though AKA I would worry about te main webbing on any stock 440 block if you decide to RPM it much above 7000 RPM on the edge on the tune up Run it slightly fat and don't push the total timing and you should be okay
Re: Ok is this going to be a problem child ? [Re: VernMotor] #1609572
04/20/14 12:28 AM
04/20/14 12:28 AM
Illinois
gearhead01 Offline
gearhead01  Offline
Illinois
I get the same 14.54:1 compression ratio.
John
1971 Satellite Sebring Plus - 14.46 @ 95.43
1977 Road Runner - N/B 11.02@ 119 Drag Radials
