TA runs like crap after first spring start up
#1609513
04/19/14 06:18 PM
04/19/14 06:18 PM
Posts: 907 Mississauga, Canada
KARLN
Mississauga, Canada
hey guys, finally started the T/A after winter storage. She started quickly but stalls as soon as I put in drive. Seems to idle okay but reving the engine makes it sputter. I'm guessing water in the gas tank? I did use stabilizer before storage but this was a brutally cold winter. Any suggestions?
Also what plug would you recommend if the engine has been modified with a stroker kit? Should the plug be a hotter or colder range from stock?
B5 Challenger T/A
Re: TA runs like crap after first spring start up
[Re: KARLN]
#1609514
04/19/14 06:29 PM
04/19/14 06:29 PM
RapidRobert
check that the AP is providing a good/immediate squirt. Might need to flush the gas. I'd go with maybe 1 heat range colder. Alot depends on the CR (how much heat the plug will see)
[Re: KARLN]
#1609516
04/19/14 06:46 PM
04/19/14 06:46 PM
RapidRobert
I'd stay where you are at, 10 would likely be too cold. 12 is very close. I'd get it going & monitor the plugs. what is your SCR? What is making you think you need to might need to change heat ranges? EDIT meant to say 1 range colder than what was in the heads OE which might have been a 13 or 14 rather than 1 range colder than what you have now especially since I did not know what you have in there. unless it's a killer motor 12 is very very close
[Re: RapidRobert]
#1609517
04/19/14 07:02 PM
04/19/14 07:02 PM
KARLN
Mississauga, Canada
just removed a plug and it's black! Going to clean off the plugs and start the engine again to see if it solves the issue. I asked the machine shop to keep the compressor as close to stock as possible. They calculated it around 10:5.
B5 Challenger T/A
[Re: KARLN]
#1609519
04/19/14 07:06 PM
04/19/14 07:06 PM
Posts: 5,894 Florida
Locomotion
Old gas remaining in the carbs may have gummed them up a bit. But either way, it wouldn't hurt to disassemble the carbs and squirt carb cleaner through all of the passages, including air bleeds. Gaskets could have shrunk also from dryness and/or temperature swings. If they look ok, perhaps retightening everything with the same gaskets, base as well, could help seal any possible air/fuel leaks. Otherwise, replace them and see if that helps.
Check diaphragms while your at it.
As mentioned, going a bit colder on plugs is a good idea. OEM 340 high compression plugs were N9Y.
[Re: Locomotion]
#1609521
04/19/14 07:54 PM
04/19/14 07:54 PM
KARLN
Mississauga, Canada
N9Y? I thought the stock plug was RN12Y? I should probably go a range colder.
B5 Challenger T/A
[Re: KARLN]
#1609522
04/19/14 08:44 PM
04/19/14 08:44 PM
Locomotion
Champion had N9Y listed for the high compression 340's through '71 and went to N12Y for the low compression versions. Not sure when they started the R-resistor and C- copper designations.
FWIW, I recall N10Y being recommended for 426 Hemi's and I used N7Y in my high compression small block bracket motors when they were available.
[Re: autoxcuda]
#1609524
04/19/14 09:17 PM
04/19/14 09:17 PM
KARLN
Mississauga, Canada
using 94 with octane boost. I think it's water in the fuel or carb issues that are causing my problem. I just cleaned the plugs and restarted and the engine is running rough and seems to flood at idle unless I keep the revs up. I hope I don't have to drain all the fuel and refill, I have almost a full tank.
B5 Challenger T/A
[Re: KARLN]
#1609525
04/19/14 09:27 PM
04/19/14 09:27 PM
RapidRobert
Hook a can of fresh gas to the fuel pump inlet & run that thru it & see if that straightens it out. Just me I would take off the carb top & see what you see. I like to lube bowl screws and spray the carb top gasket with WD40
[Re: brads70]
#1609528
04/19/14 09:37 PM
04/19/14 09:37 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Noticing your location I suggest Shell premium fuel as it contains no ethanol . Sunoco 94 (junk!)is full of ethanol. Sounds like you have a stuck float perhaps?
I think it's carb or ignition related granted you kept the tank full and added stabilizer over just one winter.
Can you idle the car a little while looking down the carbs? Wonder if one of the carbs is dumping fuel.
[Re: RapidRobert]
#1609530
04/19/14 10:12 PM
04/19/14 10:12 PM
KARLN
Mississauga, Canada
it was filled with Shell premium before storage as I heard the same about it not containing ethanol. I'm going to have my dad help me tomorrow and look down the carb to see what's happening. Ignition system is new so I doubt if it's ignition related. Plus it ran fine when I put her away for the winter.
B5 Challenger T/A
[Re: KARLN]
#1609531
04/20/14 04:42 PM
04/20/14 04:42 PM
KARLN
Mississauga, Canada
quick update. Looked down the center carb and spray seems to be good and atomized. Is there a procedure to adjust the choke and fast idle solenoid? Could the fact that I've welded my heat riser in the full open position to give original appearance be contributing to this issue?
B5 Challenger T/A
[Re: KARLN]
#1609532
04/21/14 04:41 PM
04/21/14 04:41 PM
Challenger 1
Cincinnati, Ohio
I'm betting it wasn't running very well when you parked it, even though you thought it was.
Water or condensation won't foul your plugs, tuneups do.
