'02 5.9 timing chain cover leak #1609345
04/19/14 11:42 AM
04/19/14 11:42 AM
Kentucky
dfsmopars Offline OP
Kentucky
At 120,000 the 5.9 timing chain cover appears to be leaking coolant. Of course this requires pulling the front end off the engine as well as the oil pan with the engine in the truck. This is a 4WD so the oil removal is the major concern. Any thoughts?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: '02 5.9 timing chain cover leak [Re: dfsmopars] #1609346
04/19/14 02:13 PM
04/19/14 02:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You dont have to pull the oil pan.
Re: '02 5.9 timing chain cover leak [Re: dfsmopars] #1609347
04/19/14 02:25 PM
04/19/14 02:25 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
External coolant leak?
Sure it isn't the weep hole in the water pump?
It takes gasoline to interest me.
Re: '02 5.9 timing chain cover leak [Re: VL21] #1609348
04/20/14 05:35 PM
04/20/14 05:35 PM
Truckville, the capital of NY
85_Ram_4speed Offline
My guess too also followed by the upper bypass hose, or t-stat gasket, or a pin hole in the heater hoses or rad hose, and lastly the cover and/or bolts got severly corroded causing a leak. I have either seen or experienced all the above EXCEPT the cover/bolts actually leaking
Hard to see in all those areas well, a pressure test might confirm it though. And as mentioned, no need to loosed or drop the pan, just don't forget to remove the front two pan bolts as they are held to the front cover.
Outcast Dodge guy.
Re: '02 5.9 timing chain cover leak [Re: dfsmopars] #1609349
04/20/14 11:51 PM
04/20/14 11:51 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
5.9 magnum? (not 5.9 Cummins?). Magnum, I'd agree, water pump is leaking out the weep hole under the pump shaft, bearings are gone. Check it with an inspection mirror.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: '02 5.9 timing chain cover leak [Re: GO_Fish] #1609350
04/21/14 02:15 PM
04/21/14 02:15 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I had a '99 Ram with 5.9 gas motor that developed a antifreeze leak and I was able to trace it to the t-stat gasket. It was simple fix, but hard to see with the A/C pump in the way. Fix the easy, cheap problems first and then dig deeper if you have to.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
