'02 5.9 timing chain cover leak
#1609345
04/19/14 11:42 AM
04/19/14 11:42 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
At 120,000 the 5.9 timing chain cover appears to be leaking coolant. Of course this requires pulling the front end off the engine as well as the oil pan with the engine in the truck. This is a 4WD so the oil removal is the major concern. Any thoughts?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: '02 5.9 timing chain cover leak
[Re: dfsmopars]
#1609347
04/19/14 02:25 PM
04/19/14 02:25 PM
Posts: 1,357 central Florida
VL21
central Florida
External coolant leak? Sure it isn't the weep hole in the water pump?
It takes gasoline to interest me.
[Re: VL21]
#1609348
04/20/14 05:35 PM
04/20/14 05:35 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
My guess too also followed by the upper bypass hose, or t-stat gasket, or a pin hole in the heater hoses or rad hose, and lastly the cover and/or bolts got severly corroded causing a leak. I have either seen or experienced all the above EXCEPT the cover/bolts actually leaking
Hard to see in all those areas well, a pressure test might confirm it though. And as mentioned, no need to loosed or drop the pan, just don't forget to remove the front two pan bolts as they are held to the front cover.
Outcast Dodge guy.
[Re: dfsmopars]
#1609349
04/20/14 11:51 PM
04/20/14 11:51 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
5.9 magnum? (not 5.9 Cummins?). Magnum, I'd agree, water pump is leaking out the weep hole under the pump shaft, bearings are gone. Check it with an inspection mirror.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
