Hemi Rocker Stand Question
#1609103
04/18/14 08:09 PM
04/18/14 08:09 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I have iron heads for my build up. But the previous owner had thrown in a new set of aluminum rocker stands. They have a steel insert in the middle where the head bolt goes through with a wide flange that looks to be bigger than the head of the bolt.
Question I have is this; can you use aluminum rocker stands on iron heads? Will the dissimilar metal expand and contract differently varying the clamping force on the head at those middle bolts? Do I need to use a different torque on those five bolts? I actually am thinking about using studs on the heads. I would think the same concern on torque on the dissimilar materials even with studs. Your thoughts?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Hemi Rocker Stand Question
[Re: RoadRunner]
#1609104
04/18/14 08:48 PM
04/18/14 08:48 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
Aluminum stands on iron heads are fine. With bolts or studs. Use the same torque on the bolts or studs regardless of the rocker stand material.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#1609105
04/18/14 10:08 PM
04/18/14 10:08 PM
RoadRunner
Phew. Thanks. This project has been spiraling out of control so I am glad I don't have to replace more items.
