Hemi Rocker Stand Question #1609103
04/18/14 08:09 PM
04/18/14 08:09 PM
East Aurora (Buffalo) NY
RoadRunner Offline OP
I have iron heads for my build up. But the previous owner had thrown in a new set of aluminum rocker stands. They have a steel insert in the middle where the head bolt goes through with a wide flange that looks to be bigger than the head of the bolt.
Question I have is this; can you use aluminum rocker stands on iron heads? Will the dissimilar metal expand and contract differently varying the clamping force on the head at those middle bolts? Do I need to use a different torque on those five bolts? I actually am thinking about using studs on the heads. I would think the same concern on torque on the dissimilar materials even with studs. Your thoughts?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Hemi Rocker Stand Question [Re: RoadRunner] #1609104
04/18/14 08:48 PM
04/18/14 08:48 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Aluminum stands on iron heads are fine. With bolts or studs. Use the same torque on the bolts or studs regardless of the rocker stand material.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Rocker Stand Question [Re: Hemi_Joel] #1609105
04/18/14 10:08 PM
04/18/14 10:08 PM
Phew. Thanks. This project has been spiraling out of control so I am glad I don't have to replace more items.
2023 Ford Mach 1
Re: Hemi Rocker Stand Question [Re: RoadRunner] #1609106
04/19/14 01:51 AM
04/19/14 01:51 AM
Make sure and set the valve lash hot, especially with the aluminum stands
