Ditching the Points #1608625
04/17/14 04:09 PM
04/17/14 04:09 PM
West Palm Beach, Florida
Copper Dart Offline OP
Mancini sells an Electronic Ignition kit to convert my '67 383. Have 2 listed, one is a Prestolite, What is the difference? Mopar Performance or Presto? Street/Stock Cruiser not a Race Car.
Also I need the steel fuel line from the Stock fuel pump/fuel filter to the #1407 Eddy carb, anyone know the part number? The carb inlet is on the right side rearward corner. I have a rubber fuel line running from the filter to the carb and I dont like it.
Help if you can, Thanks
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Ditching the Points [Re: Copper Dart] #1608626
04/17/14 04:21 PM
04/17/14 04:21 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The Prestolite is factory dual point only.
Re: Ditching the Points [Re: 62maxwgn] #1608627
04/17/14 05:04 PM
04/17/14 05:04 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
PerTronix is $89 at Summit...
Re: Ditching the Points [Re: Copper Dart] #1608628
04/17/14 05:32 PM
04/17/14 05:32 PM
Pertronix 2 with matching Pertronix 2 coil. Best price would be from one of the ebay sellers. It requires a point dist with tight bushings & yours is 45+ years old. Autozone reportedly sells rebuild ones for cheap (exchange). Just me I would get a JY 70's electronic dist and mount an HEI module under the dist & a killer E coil, I'd get a length of tubing with the inverted flare male fittings on each end of the length you need from your parts house & bend it to fit. It's hard so I would heat it
Re: Ditching the Points [Re: RapidRobert] #1608629
04/17/14 06:55 PM
04/17/14 06:55 PM
States it's a electronic ignition system. I'm confused (again)
They sell the fuel line for 25+/-
Mom.
Ricky Valdes
Re: Ditching the Points [Re: Copper Dart] #1608630
04/17/14 09:30 PM
04/17/14 09:30 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Pointless ignition = electronic ignition; Same-o same-o.
Stock electronic ignition IS pointless. The PerTronix, if I am not mistaken also eliminates the EIM (which you wouldn't have) but, others? please correct me if I got this wrong.
Re: Ditching the Points [Re: Scott Carl] #1608631
04/17/14 09:49 PM
04/17/14 09:49 PM
Yes they are both electronic ign. The pertronix combines the "dist pickup" and the "ECU" into one mini electronic box that fits inside the dist where the points once resided. 2 wires from it out to the coil (-) and (+) primary terminals & I believe you connect the ign1 (run) blue wire switched 12V and the brown wire ign2 (crank) wires together & run them to the coil positive primary terminal completely eliminating/bypassing the ballast resistor & with no resistor is why you need the special Pertronix coil, that & it's likely hotter
Re: Ditching the Points [Re: RapidRobert] #1608632
04/17/14 09:55 PM
04/17/14 09:55 PM
Central TX
roe Offline
roe  Offline
Central TX
Or you can just gut the ballast resister, and solder in an 8 guage wire to get a full 12 volts across it. I thought it was a much cleaner install that way. And if you care about stock looking at all, that's the ticket. You just have 2 wires coming from the dizzy to the coil instead of one.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Ditching the Points [Re: roe] #1608633
04/17/14 10:29 PM
04/17/14 10:29 PM
Reliability of the pertronix system good? Sounds like the ticket for stock appearing! I like the idea of modifying the ballast resistor to supply full 12 volts without changing its appearance. Nice
Mom.
Ricky Valdes
Re: Ditching the Points [Re: Copper Dart] #1608634
04/17/14 10:57 PM
04/17/14 10:57 PM
I've only heard of a very few failures with it. I'm about to pull the trigger on a Pertronix 3 as an eBay seller is gonna discount me a slight bit. It (the 3 system) has a multispark incorporated into that minibox
Re: Ditching the Points [Re: RapidRobert] #1608635
04/17/14 11:07 PM
04/17/14 11:07 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
I am doing the conversion soon but using the GM hei module and coil and triggered with a mopar electronic distibuter,if the module fails you can get it going again from any parts store.Might want to do a search on the pertronix stuff,seems the orignal version isn't to good.
Re: Ditching the Points [Re: wannadrag] #1608636
04/17/14 11:26 PM
04/17/14 11:26 PM
How do you use the GM hei coil on a Mopar distributor? I'm missing something. Pictures please.
Mom.
Ricky Valdes
Re: Ditching the Points [Re: Copper Dart] #1608637
04/17/14 11:54 PM
04/17/14 11:54 PM
You use the HEI module mounted on a piece of alum plate mounted seperately outside the dist or mount it on an alum plate bolted to the underside of the dist (hides the chebby part). Someone (eBay likely) sells the plate but it is pricey & you can make one easily. You'd use a regular round coil any type of your choice of ohms not the squarish OE one that looks like a transformer that fits in the HEi dist. I ran that with an Accel super coil the big yellow beast 30 yrs ago & it was a killer setup. You're supposed (per Accell) to run an .8 ohm ballast with it but at the time I did not know any better but it never burned out & ran like a scalded dog & with an aftermarket HEI module it've likely run even better. Speedway motors has an HEI "dynamod" and my setup way back used an OE black one out of a '75 chebby. dont forget the Radio Shack heat sink paste between the module and the alum plate for heat dissipation
Re: Ditching the Points [Re: Copper Dart] #1608638
04/18/14 03:25 AM
04/18/14 03:25 AM
Central TX
roe Offline
roe  Offline
Central TX
Mine has been on for 3-3.5 years, no issues. I used a rebuilt points dizzy from Autozone for like $30.
Like Rapid said, I've only heard of very few failures. When I was deciding whether to get it, most folks were reporting 10 years on original pieces. Almost no failures to speak of. Carry a set of points in the glovebox, and you wouldn't be stranded even if you happened to be in that very unlucky few.
Re: Ditching the Points [Re: roe] #1608639
04/18/14 09:41 AM
04/18/14 09:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used the Petronix and had no problems.Hookup was simple and quick.I agree get a length of steel line and bend yout fuel line.Rocky
Chrysler Firepower
Re: Ditching the Points [Re: therocks] #1608640
04/18/14 10:29 AM
04/18/14 10:29 AM
Andrewh Online content
Andrewh  Online Content
http://www.carcraft.com/techarticles/1311_convert_a_ford_or_chrysler_ignition_to_gm_hei/
with pictures.
I think price is a bit of a wash. pertronix vs the hei conversion.
I prefer petronix.
it literally was the easiest mod I ever made to a distributer.
took 10 min. all the other swaps or replacments always made me reindex the thing so it would fire up the first time.
that was a drop in a fired right up.
never ran one for more than 5 years, but it was still running when I got rid of the motor.
Re: Ditching the Points [Re: Copper Dart] #1608641
04/18/14 11:26 AM
04/18/14 11:26 AM
3rd rock
K
kloyiod Offline
kloyiod  Offline
K
3rd rock
[quote I have a rubber fuel line running from the filter to the carb and I dont like it.
Your very wise not to like it, I don't like seeing it either. Any of the aft market repop places have them, here's Year Ones. https://www.yearone.com/Product/1966-74-a-b-e-body/qrf65
If your carb has the nipple end, you can cut off the flare and use a short section of hose. I'm running 2 of the 1st gen Pertronix with no problems for over 20 years now. You can use stock coil or the blaster coil, either works fine. Hook directly to the coil. No need to bypass the ballast unless you want to. I didn't on mine.
Re: Ditching the Points [Re: Andrewh] #1608642
04/18/14 12:30 PM
04/18/14 12:30 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
with pictures.
I prefer petronix.
Andrew,
Thanks for that link!
I started out reading this passively but the more I read the more intrigued I am. The article (and this topic), however raises a couple questions:
1. In the article, They say the old oil filled coils must be mounted vertically or they will overheat. Nearly every stock app I can think of has the coil mounted horizontally on the engine. What's up with that??
2. Just so I'm clear, this system (in the link) does eliminate the stock ECU; yes? So those wires connecting it are the ones used to connect to the GM thingy?
3. (okay one more) On the Pertronix system, there appears to be only a couple wires that will come out of the distributor and connect to the coil. If this system also eliminates the ECU, what happens to all the wires (5, iirc) that are connected to it? Are they the same ones that connect to the coil and dist. so they are eliminated as well?
Thanks,
Scott
Re: Ditching the Points [Re: kloyiod] #1608643
04/18/14 12:40 PM
04/18/14 12:40 PM
thanks to all for your vast Mopar knowledge and willingness to share I hope to see "SOME" of you at a Car Show some day.
Rumor has it that my wife has ordered the kit from Mancini as a surprize. Thanks bro!
I would like to try the GM style personally, clever mod IMO.
Mancini may have that fuel line Year One is selling too.
Thanks again.
Mom.
Ricky Valdes
Re: Ditching the Points [Re: Scott Carl] #1608644
04/18/14 01:03 PM
04/18/14 01:03 PM
Central TX
roe Offline
roe  Offline
Central TX
with pictures.
I prefer petronix.
Andrew,
Thanks,
Scott
You can just go with the epoxy filled coil so that it's not a worry. Lots of folks have mounted the oil filled ones horizontally and not had issues.
