rebuilding a dual point distributor #1608603
04/17/14 03:24 PM
04/17/14 03:24 PM
California
mickm Offline OP
mickm  Offline OP
California
i picked up a 68 440 dual point at spring fling, and want to do a restoration as a project, probably long term!
where do i find parts and such for these? like the screws that hold the vacuum advance on are pretty beat up.
and can anyone give basic info on what needs to be done? like the vacuum advance, (which does work), has a lot of surface crap on it, and so needs to be cleaned up, but i don't know the best way to do this.
any thoughts or pointers appreciated!
Re: rebuilding a dual point distributor [Re: mickm] #1608604
04/17/14 04:18 PM
04/17/14 04:18 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
MegaParts has a screw/washer kit for them. They are very simple to completely pull apart, clean, glass bead the housing and paint. I've been lucky with the few I have rebuilt, the shaft bushings were still tight and didn't need to be replaced. The oiler pulls out with a little force, so that you can clean or replace it with a new one (Crossram Connection makes them new).
Re: rebuilding a dual point distributor [Re: 70440+6bbl] #1608605
04/17/14 04:25 PM
04/17/14 04:25 PM
California
mickm Offline OP
mickm  Offline OP
California
thanks, thats the kind of stuff i'm looking for.
what about the vacuum advance, how do i clean that up?
Re: rebuilding a dual point distributor [Re: mickm] #1608606
04/17/14 04:28 PM
04/17/14 04:28 PM
California
mickm Offline OP
mickm  Offline OP
California
oh, and another question, where do i find quality points?
Re: rebuilding a dual point distributor [Re: mickm] #1608607
04/17/14 04:37 PM
04/17/14 04:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can make them look like this with a little effort.
As for points,get in touch with Joe Sixpack
Re: rebuilding a dual point distributor [Re: 62maxwgn] #1608608
04/17/14 05:41 PM
04/17/14 05:41 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Joes sixpack
Re: rebuilding a dual point distributor [Re: 5carguy] #1608609
04/17/14 11:26 PM
04/17/14 11:26 PM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
Pretty good DIY dual point restoration article with lots of photos here:
The text - http://roadtrip.yearone.com/search/label/MOPAR
and scroll down 1/3 of the page.
The photos are here:
https://www.flickr.com/photos/39161502@N06/sets/72157626179045400/
Re: rebuilding a dual point distributor [Re: 62maxwgn] #1608610
04/19/14 10:35 AM
04/19/14 10:35 AM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Who is making the tags now. Bill Rolik out of Jersey lost all of his dies for making them. He only has select ones left
Re: rebuilding a dual point distributor [Re: LemonTwiist] #1608611
04/19/14 12:34 PM
04/19/14 12:34 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I'm pretty sure that you can buy them from Norm Brady at The Crossram Connection.
Re: rebuilding a dual point distributor [Re: mickm] #1608612
04/19/14 12:42 PM
04/19/14 12:42 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Maxwagons look better than mine do Since I don't have any other way, I lightly glass bead mine and then polish the stamped metal half of the advance with a fine wire wheel. The cast portion looks to have had some sort of plating on it. If you blast it too long, you will see the raw metal color start to show through.
I just pulled the distributor out of my Bee the other night to clean it up and "detail" it and throw some new points in.
Re: rebuilding a dual point distributor [Re: 70440+6bbl] #1608613
04/19/14 12:50 PM
04/19/14 12:50 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
What I started with...
Re: rebuilding a dual point distributor [Re: 70440+6bbl] #1608614
04/19/14 11:13 PM
04/19/14 11:13 PM
Does anyone have a distributor machine anymore for setting the dwell ?
I recall doing this in high school I also remember checking the dwell buy putting a matchbook to block off one set of points....
Re: rebuilding a dual point distributor [Re: 70440+6bbl] #1608615
04/20/14 12:13 AM
04/20/14 12:13 AM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
I think maybe HP Mike in Jersey
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: rebuilding a dual point distributor [Re: Q5_Ed] #1608616
04/20/14 12:30 AM
04/20/14 12:30 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Also,member Beeware.( Paul Petcou )You will have it back in a few days.
Re: rebuilding a dual point distributor [Re: ] #1608617
04/20/14 04:04 AM
04/20/14 04:04 AM
California
mickm Offline OP
mickm  Offline OP
California
damn, but it's been a long time! i remember something about that, but it's not coming all back...
is there something different you have to do when setting the dwell on dual point distributors?
Re: rebuilding a dual point distributor [Re: mickm] #1608618
04/20/14 05:38 PM
04/20/14 05:38 PM
Block off one set of points, set dwell....then switch.....so you set the dwell on each set seperately, then hopefully you end up with the correct combined dwell
Re: rebuilding a dual point distributor [Re: ] #1608619
04/20/14 09:36 PM
04/20/14 09:36 PM
Orlando, FL
ChargerKnight66 Offline
Orlando, FL
You mean like this? I'm checking the advance curve...
Re: rebuilding a dual point distributor [Re: ChargerKnight66] #1608620
04/21/14 10:53 AM
04/21/14 10:53 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Boy would I like to own one of those.Been looking for one.
Re: rebuilding a dual point distributor [Re: ChargerKnight66] #1608621
04/21/14 01:19 PM
04/21/14 01:19 PM
Re: rebuilding a dual point distributor [Re: ] #1608622
04/21/14 02:05 PM
04/21/14 02:05 PM
California
mickm Offline OP
mickm  Offline OP
California
saw a couple of guys carrying one of those through the swap meet at spring fling. looked like a good find!
