Can you use a Cometic head gasket on a #1607971
04/15/14 09:50 PM
04/15/14 09:50 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
" O " ringed mopar mega block? Having a serious problem with my SCE copper head gaskets leaking coolant. Tried everything to seal them up with no results.
So I want to try and use a Cometics head gasket. Never used them before. Will a Cometics head gasket work with an O ringed block?
Re: Can you use a Cometic head gasket on a [Re: Sammy] #1607972
04/15/14 10:14 PM
04/15/14 10:14 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I don't think so. The center gasket is stainless, it probably won't conform to the -ring. I'd give them a call.
Re: Can you use a Cometic head gasket on a [Re: Sammy] #1607973
04/15/14 10:15 PM
04/15/14 10:15 PM
Cab_Burge Online work
Cab_Burge  Online Work
Sounds like you need a reciever groove to help seal the motor Regardless of which type of gasket
Re: Can you use a Cometic head gasket on a [Re: Cab_Burge] #1607974
04/15/14 10:31 PM
04/15/14 10:31 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Cab, it has always worked at 13.5 compression but I just redid the motor and it now has 15.3 compression. 5 passes and its leaking, tore it down, copper coated the gaskets till tacky and retorued it down. It is still leaking badly, even worse.
Re: Can you use a Cometic head gasket on a [Re: Sammy] #1607975
04/15/14 10:45 PM
04/15/14 10:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Tap a stainless wire in to the groove and file it
flush
Re: Can you use a Cometic head gasket on a [Re: MR_P_BODY] #1607976
04/16/14 01:52 AM
04/16/14 01:52 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Just put moroso stop leak in it. Every set of cosmetics I've used has needed it too.
Re: Can you use a Cometic head gasket on a [Re: dizuster] #1607977
04/16/14 08:48 AM
04/16/14 08:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Use UltraCopper silicone around all water and oil holes,let cure 100% and retorque the head bolts.
Re: Can you use a Cometic head gasket on a [Re: B G Racing] #1607978
04/16/14 09:48 AM
04/16/14 09:48 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That sounds reasonable Bob. I would caution to not make it too thick as you might run the risk of it splitting when put under torque load, just a thought.
Should be no reason not to be able to get the water sealed up.
Aren't the SCE's silicone beaded to start with?
Re: Can you use a Cometic head gasket on a [Re: roadhazard] #1607979
04/16/14 04:12 PM
04/16/14 04:12 PM
They can be if you order the correct part number The ICS Titan series have the teflon beads on them, the Titan don't, I think
Re: Can you use a Cometic head gasket on a [Re: Cab_Burge] #1607980
04/16/14 04:34 PM
04/16/14 04:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have been using UltraCopper on copper head gaskets for years with zero coolant leaks.O-ring and reciever grooves with copper gaskets is a foolproof way of sealing compression,but unless you get 100% annealing of the o-ring in the gasket and 100% gasket enbeddment into the reciever grooves the flat surfaces tend to not seal.Apply a coating of UltraCopper silicone around all coolant and oil passages on both the block and head side,being carefull not to put it to close to the oil passages so it doesn't migrate into the passages causing restriction.It is important to snug down the head bolts and allow the silicone to cure for at least 24 hours,then final torque the bolts.It works better than any of the coated copper gaskets.Sometimes the copper gaskets are too hard and must be heated to get proper annealing and some gaskets are stamped from a sheet of copper and the thickness varies.Soft evenly rolled gaskets are the best and ones that are lasered or CNC cut are more uniform in thickness.
If your block and,or heads are o-ringed or have reciever grooves and you want to use Cometics then fill the grooves with a filler like Alvins' LabMetal or similar.
Re: Can you use a Cometic head gasket on a [Re: B G Racing] #1607981
04/16/14 07:28 PM
04/16/14 07:28 PM
mi
dirty magnum Offline
mi
Sammy use hylamar to seal your head gaskets, will never leak again 2 even coats sprayed on.
Re: Can you use a Cometic head gasket on a [Re: dirty magnum] #1607982
04/16/14 07:32 PM
04/16/14 07:32 PM
dogdays Offline
dogdays  Offline
Hylomar is the stuff, just don't get it on your fingers.
R.
Re: Can you use a Cometic head gasket on a [Re: dogdays] #1607983
04/16/14 10:11 PM
04/16/14 10:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
R.
My blown SB had an O-ringed factory 340 block. I decided not to use the O-rings and filled the grooves with JB weld. Scrapped it flush with a razor blade after it dried. Ran it that way for years at 12PSI with no gasket failure.
Doug
Re: Can you use a Cometic head gasket on a [Re: dvw] #1607984
04/16/14 11:16 PM
04/16/14 11:16 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Are you using new gaskets? If the O-ring stands out more than .012 you will also have trouble. A .010 deep .041 wide receiver will allow the gasket to pinch tighter. Some o-ring jobs are horrible. The fit of the ends is important. Cosmetics will work with job weld or copper o-rings filed flat. As always if the surfaces are not flat nothing will work
Re: Can you use a Cometic head gasket on a [Re: Leon441] #1607985
04/16/14 11:22 PM
04/16/14 11:22 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Could you deck the block to erase the grooves, then adjust with custom gasket??
