1970 Cuda Driver Side Mirror Mounting Hole Locations #1607949
04/15/14 09:17 PM
04/15/14 09:17 PM
Tempe, AZ
loco340cuda Offline OP
Tempe, AZ
I just had the door skin on my drivers door replaced on my 70 Cuda and I need the correct dimensions for where to drill the three holes for the mirror. I also need the diameter of the center hole which is used for the remote cable to go thru.
-Thanks
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: loco340cuda] #1607950
04/16/14 12:16 AM
04/16/14 12:16 AM
Ashland City, Tennessee
Aar1064 Offline
Aar1064  Offline
If you're not in a hurry I could make you a template from my holes in door and put it in the mail. I'd of course take pics so you could verify correct placement and locations. PM me if that would work.
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: Aar1064] #1607951
04/16/14 12:03 PM
04/16/14 12:03 PM
Tempe, AZ
Tempe, AZ
PM sent
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: loco340cuda] #1607952
04/16/14 11:33 PM
04/16/14 11:33 PM
Aar1064 Offline
Aar1064  Offline
Ok I took some pics with measurements. I measured from the inside door edge to get the vertical measurements.
Looks like 2 3/8 for first hole
2 5/16 for center hole
2 5/16 for rear hole
Horizontally from front of door edge is 17 1/4 and 20 1/4.
This is an original door and not sure how exact these measurements are compared to others.
Hope this helps
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: Aar1064] #1607953
04/16/14 11:34 PM
04/16/14 11:34 PM
Aar1064 Offline
Aar1064  Offline
Center hole
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: Aar1064] #1607954
04/16/14 11:36 PM
04/16/14 11:36 PM
Aar1064 Offline
Aar1064  Offline
Rear hole
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: Aar1064] #1607955
04/16/14 11:46 PM
04/16/14 11:46 PM
Aar1064 Offline
Aar1064  Offline
Another
Re: 1970 Cuda Driver Side Mirror Mounting Hole Locations [Re: Aar1064] #1607956
04/16/14 11:48 PM
04/16/14 11:48 PM
Aar1064 Offline
Aar1064  Offline
Front edge
