727 Trans - Cold Start Delayed Engagement #1607823
04/15/14 12:54 PM
04/15/14 12:54 PM
NW Chicago suburban area
Mopar Mitch Offline OP
Although my 727 trans was recently rebuilt, whenever I start it cold (from an overnight or extended sitting/storage period), it takes a few moments (~10-15 seconds) for the trans to engage into the gear (say, simply to back out of the garage), then still it seems to have to wait another couple moments to actually move the car. After it runs for a few minutes it seems to be fine and I can drive away for my cruise (typically to a race or show). If it makes any difference, the trans is actually a 1972 model 727 that I've owned and run in the car since the late 1970s.
I have an auxiliary trans cooler (newly replaced), old BM Holeshot converter (bought ~1978), and a basic new shift kit (still fully automatic, but can shift manually if desired up/down). Fluid level is proper when warmed up. It's been like this for many years, even before the recent rebuild.
Car is not driven much. Any suggestions appreciated.
Re: 727 Trans - Cold Start Delayed Engagement [Re: Mopar Mitch] #1607824
04/15/14 01:03 PM
04/15/14 01:03 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
Yup, Pretty typical of most 727's. Im not sure how to prevent that from happening as I think its torque convert drain back. Arlen Vanke told me about some valve to install in a tranny line that helps with that but he moved away before he could help me fix that....Mine all do it too..
Re: 727 Trans - Cold Start Delayed Engagement [Re: Mopar Mitch] #1607825
04/15/14 01:06 PM
04/15/14 01:06 PM
Yanceyville, NC
JGriffit Offline
JGriffit  Offline
Yanceyville, NC
Sounds like converter is draining out due to not being driven. Easy fix is put it in neutral for a few seconds after starting. That fills the converter much faster than sitting in park. Same issue with my Challenger
99 Dodge Avenger Best Machine 428 ET 8.90 150MPH
BLP Carbs Ultimate Converter Concepts
Re: 727 Trans - Cold Start Delayed Engagement [Re: Mopar Mitch] #1607826
04/15/14 01:10 PM
04/15/14 01:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its just the conv draining down... you can start it
in neutral and its fills quickly OR the newer trucks
have a anti drain back check valve in the line that
you can install
Re: 727 Trans - Cold Start Delayed Engagement [Re: MR_P_BODY] #1607827
04/15/14 02:20 PM
04/15/14 02:20 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
My 727 used to do the same thing before it was rebuilt. My uncle rebuild the trans for me and the following is what was wrong: burnt low/reverse band, Pump gears and overrunning clutch rollers and springs.
He said that since the pump gears were bad the pump was not filling the converter fast enough.
Not saying this is what is wrong with yours but thought I'd share.
Re: 727 Trans - Cold Start Delayed Engagement [Re: JGriffit] #1607828
04/15/14 03:59 PM
04/15/14 03:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is correct as most 727's dont fill the converter in Park unless it was modified. Does not hurt anything as mine does it also. Just start in neutral as was said and it will fill in about 5 to 10 seconds. Or install the drainback valve if it bugs you alot. Ron
Re: 727 Trans - Cold Start Delayed Engagement [Re: 383man] #1607829
04/15/14 06:05 PM
04/15/14 06:05 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
transaction makes a valve that goes in valvebody to fill in park
Re: 727 Trans - Cold Start Delayed Engagement [Re: Mopar Mitch] #1607830
04/16/14 03:31 AM
04/16/14 03:31 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Or Trans-go SK-TFSC, has modified TV that will allow the converter to charge in park. About $27 on flea-bay.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: 727 Trans - Cold Start Delayed Engagement [Re: 1KoolBee] #1607831
04/16/14 08:50 PM
04/16/14 08:50 PM
I appreciate everyone's feedback! Have a great day and enjoy your racing summer!
Re: 727 Trans - Cold Start Delayed Engagement [Re: Mopar Mitch] #1607832
04/18/14 10:57 PM
04/18/14 10:57 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I just had my trans out for the same symptoms.Turned out there was too much clearance between the pump gears and the stater causing me to loose pressure to the 'vert.Installed new stater and all is good,snaps right in to gear.
Your results may vary
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
