727 Trans - Cold Start Delayed Engagement
#1607823
04/15/14 12:54 PM
04/15/14 12:54 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Although my 727 trans was recently rebuilt, whenever I start it cold (from an overnight or extended sitting/storage period), it takes a few moments (~10-15 seconds) for the trans to engage into the gear (say, simply to back out of the garage), then still it seems to have to wait another couple moments to actually move the car. After it runs for a few minutes it seems to be fine and I can drive away for my cruise (typically to a race or show). If it makes any difference, the trans is actually a 1972 model 727 that I've owned and run in the car since the late 1970s.
I have an auxiliary trans cooler (newly replaced), old BM Holeshot converter (bought ~1978), and a basic new shift kit (still fully automatic, but can shift manually if desired up/down). Fluid level is proper when warmed up. It's been like this for many years, even before the recent rebuild.
Car is not driven much. Any suggestions appreciated.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: 727 Trans - Cold Start Delayed Engagement
[Re: Mopar Mitch]
#1607825
04/15/14 01:06 PM
04/15/14 01:06 PM
Posts: 39 Yanceyville, NC
JGriffit
Yanceyville, NC
Sounds like converter is draining out due to not being driven. Easy fix is put it in neutral for a few seconds after starting. That fills the converter much faster than sitting in park. Same issue with my Challenger
99 Dodge Avenger Best Machine 428 ET 8.90 150MPH BLP Carbs Ultimate Converter Concepts
[Re: Mopar Mitch]
#1607826
04/15/14 01:10 PM
04/15/14 01:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its just the conv draining down... you can start it in neutral and its fills quickly OR the newer trucks have a anti drain back check valve in the line that you can install
[Re: JGriffit]
#1607828
04/15/14 03:59 PM
04/15/14 03:59 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
This is correct as most 727's dont fill the converter in Park unless it was modified. Does not hurt anything as mine does it also. Just start in neutral as was said and it will fill in about 5 to 10 seconds. Or install the drainback valve if it bugs you alot. Ron
[Re: Mopar Mitch]
#1607830
04/16/14 03:31 AM
04/16/14 03:31 AM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
Or Trans-go SK-TFSC, has modified TV that will allow the converter to charge in park. About $27 on flea-bay.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: Mopar Mitch]
#1607832
04/18/14 10:57 PM
04/18/14 10:57 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I just had my trans out for the same symptoms.Turned out there was too much clearance between the pump gears and the stater causing me to loose pressure to the 'vert.Installed new stater and all is good,snaps right in to gear. Your results may vary
