B-Body Battery in Trunk #1607626
04/15/14 12:46 AM
04/15/14 12:46 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Can anyone tell me what kit they used to put the battery in the trunk? The battery that you used and some pictures would be nice. I'd like to run a really large AGM or Optima of some sort.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: B-Body Battery in Trunk [Re: AlexP] #1607627
04/15/14 12:52 AM
04/15/14 12:52 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
made my own setup with a ford #mt 65 battery
1.39 9.85 - 137 mph
Re: B-Body Battery in Trunk [Re: AlexP] #1607628
04/15/14 12:53 AM
04/15/14 12:53 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How about two?
Tray was fabbed from 1/2 angle. Hold downs were 1/2 angle aluminum.
Doug
Re: B-Body Battery in Trunk [Re: dvw] #1607629
04/15/14 12:55 AM
04/15/14 12:55 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The tray w/o batterys
Re: B-Body Battery in Trunk [Re: AlexP] #1607630
04/15/14 06:46 AM
04/15/14 06:46 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Just my opinion, but I'd opt to leave it under the hood and use a lightweight modern battery instead.
The weight of 20-50ft of 1/0 cable certainly adds up. Also, consider the aggravation of voltage drop, high resistance grounds, hot start issues, cable routing, and the real potential for meltdown failure with 25ft of constantly hot line running under the carpet day and night.
If you do choose the trunk route, figure out your total maximum potential amperage load first. You will probably need larger capacity wire than what is provided with most cheapo kits.
ECU, injectors, fans, pumps, stereo, headlights, horn, tailights, domelight, A/C, signals, markers, brake lights, 12v acc, oxygen sensors, ect.
Re: B-Body Battery in Trunk [Re: topbrent] #1607631
04/15/14 04:21 PM
04/15/14 04:21 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Since mine is a street car I mounted mine in a plastic marine case. That way any thing I put in the trunk does not get any battery acid on it. Ron
Re: B-Body Battery in Trunk [Re: 383man] #1607632
04/15/14 04:24 PM
04/15/14 04:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Then I mounted my cut out switch on the case. And since I did not want to drill any holes in the car I drilled a hole in the taillite lens. That way if I ever put it back to stock I only have to replace the taillite lens. Ron
Re: B-Body Battery in Trunk [Re: 383man] #1607633
04/15/14 04:56 PM
04/15/14 04:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Here is my "kit"...lol
I took the battery tray from the front, and bolted it to the floor.
Two 3/8" rods through the floor with a simple strap at the top... done.
Re: B-Body Battery in Trunk [Re: AlexP] #1607634
04/15/14 06:50 PM
04/15/14 06:50 PM
Az
Crizila Offline
Crizila  Offline
Az
Used a Summit kit #SUM-G2131-K and Flaming River kit #FLA-FR1003-2.
Fastest 300
Re: B-Body Battery in Trunk [Re: AlexP] #1607635
04/15/14 06:54 PM
04/15/14 06:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The exact position of the battery changes your weight distribution (duh), but also your weight transfer.
The distribution: weight directly over the axle is 100% (the actual battery weight) on the rear wheels, and nothing on the front.
As the same weight moves back toward the bumper, the rear weight goes up (over 100%) and cantilevers weight off the front wheels. If hung on a tray out the back, a 100 lb. battery could add 200 lbs. etc.
The transfer: The distance between the axle center and the battery affects how quickly the car rotates around the axle on launch - greater distance (high polar momentum) slows down rotation. This is both front-to-back, but also height - the box can be raised so that the trunk lid just closes.
Expect to observe and tweak your suspension setting as needed.
Boffin Emeritus
Re: B-Body Battery in Trunk [Re: polyspheric] #1607636
04/16/14 12:39 AM
04/16/14 12:39 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Even though its just a street / strip car, I wanted it to be fully legal. So, I used a sealed & vented Taylor battery box. Shutoff is a Summit 250 amp waterproof rotary switch.
Re: B-Body Battery in Trunk [Re: StealthWedge67] #1607637
04/16/14 12:41 AM
04/16/14 12:41 AM
Puyallup, WA
Puyallup, WA
Re: B-Body Battery in Trunk [Re: StealthWedge67] #1607638
04/16/14 01:08 AM
04/16/14 01:08 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Left the battery in the front.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: B-Body Battery in Trunk [Re: MoparBilly] #1607639
04/16/14 01:10 AM
04/16/14 01:10 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Put a big bottle in the trunk! Much better performance than just swapping the battery back there...
Re: B-Body Battery in Trunk [Re: 383man] #1607640
04/16/14 01:27 AM
04/16/14 01:27 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why on the drivers side?
Re: B-Body Battery in Trunk [Re: Thumperdart] #1607641
04/16/14 02:19 AM
04/16/14 02:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I was waiting for someone to ask as I know they say the right side is best. But I only had enough cable to reach to the left side and I really dont think I would have noticed any difference on the right side. I mean this has worked fine for me and I did not have to buy anymore cable. When cash is tight you improvize. Ron
Re: B-Body Battery in Trunk [Re: StealthWedge67] #1607642
04/16/14 02:21 AM
04/16/14 02:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats really a nice battery box but not cheap. So thats why I used the marine case as it was given to me for free but the one you use is the one I plan to get one day. Ron
Re: B-Body Battery in Trunk [Re: 383man] #1607643
04/16/14 02:29 AM
04/16/14 02:29 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I get it................It may act better on the pass. side or not.............
Re: B-Body Battery in Trunk [Re: 383man] #1607644
04/16/14 02:38 AM
04/16/14 02:38 AM
Puyallup, WA
Puyallup, WA
I'm with you, Ron.... Budget plays a big part in most decisions on the car. But what I didn't want was to go to the track and be told to go home because I wasn't legal.
