Brake light switch issue #1606160
04/12/14 01:50 AM
04/12/14 01:50 AM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
So I have had my car apart since 2009. I am putting it together and ran across an issue with the brake light switch. I never took the pedals out, and only replaced the master cylinder. Now the brake light switch is too far to the drivers side, and slightly too high. It is hard to tell from the picture, but it is about the bolt head length away. What am I missing?? Is the bolt in backwards?? Any help is appreciated!!! Thanks!!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Brake light switch issue [Re: Prodart440] #1606161
04/12/14 02:10 AM
04/12/14 02:10 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks like the switch bracket is bent and out of adjustment.
Re: Brake light switch issue [Re: Prodart440] #1606162
04/12/14 03:52 AM
04/12/14 03:52 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Looks to me that the switch is not in the bracket at a 90 degree angle as it should be. Notice how the switch/clip is leaning to the right in relation to the mounting hole area. Try straighening it, that will move the contact towards the rod. In addition to that, it is possible the bracket is bent a little as mentioned already.
Re: Brake light switch issue [Re: Prodart440] #1606163
04/12/14 12:27 PM
04/12/14 12:27 PM
You want the white round plastic head on the switch plunger to be way over to the pass side so it contacts the pedal arm not the MC pushrod or the bolt head. As said pull the wires/remove the switch/bracket & bend it flat & mock it back up. It sure seems like it is way off (but as we know pic perspective does lie) which I ain't grasping how that happened since you never moved/unbolted the mini screw but only undid the big bolt/nut to replace the MC
Re: Brake light switch issue [Re: Prodart440] #1606164
04/12/14 01:22 PM
04/12/14 01:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
What year / model, stick or auto ??? maybe someone can snap a pic of theirs before you start bending /tweaking/modifying
Re: Brake light switch issue [Re: TJP] #1606165
04/12/14 01:26 PM
04/12/14 01:26 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
is it possible that a spacer is missing???
Is the M/C pushrod going straight ahead or at an angle ??
Re: Brake light switch issue [Re: TJP] #1606166
04/12/14 01:37 PM
04/12/14 01:37 PM
Avondale AZ
Avondale AZ
68 road runner automatic. The push rod is coming out straight. Is there supposed to be a spacer???
Aaron
68 Coronet 440
Re: Brake light switch issue [Re: Prodart440] #1606167
04/12/14 08:32 PM
04/12/14 08:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Just crawled up underneath the dash of my 68 Charger (in limited door opening space) OUCH!!!! you owe me, LOL
Does not Appear to be a spacer. The switch is actuated by the
back side/ top angle of the pushrod. Hope that makes sense.
So it would appear that your switch as pictured needs to go towards the right or passenger side of the vehicle. is the bracket slotted left to right for the switch position ???
hope this helps a bit
Re: Brake light switch issue [Re: TJP] #1606168
04/12/14 08:48 PM
04/12/14 08:48 PM
Andrewh Offline
Andrewh  Offline
I had a similar problem when I changed out boosters.
I built a small bracket that bolted up to the pedal, so when it moved to the switch there was more surface area to hit the button on it.
Re: Brake light switch issue [Re: Andrewh] #1606169
04/12/14 11:18 PM
04/12/14 11:18 PM
northern illinois
jburt Offline
jburt  Offline
northern illinois
this help any?
Re: Brake light switch issue [Re: jburt] #1606170
04/12/14 11:49 PM
04/12/14 11:49 PM
Ahhh so unlike A bodies (All I work on ex a D100 truck or 2) where the round nub is actuated from the brake pedal arm, B bodies make contact on the rear end of the pushrod hex. I learned sumpin today
Re: Brake light switch issue [Re: jburt] #1606171
04/13/14 02:26 AM
04/13/14 02:26 AM
Avondale AZ
Avondale AZ
So I took my bracket off. It looks nothing like the above picture of the 68 Charger. The bracket is bent, so now I am looking through my pile of parts to see if I have another one. Thanks for all the help!!!!
Aaron
68 Coronet 440
Re: Brake light switch issue [Re: Prodart440] #1606172
04/13/14 11:56 AM
04/13/14 11:56 AM
post (with a pic if you can) how it turns out
Re: Brake light switch issue [Re: RapidRobert] #1606173
04/13/14 02:19 PM
04/13/14 02:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Easy fix.Just take the switch out put the bracket in a vice and bend it some.Ive seen them bent worse than that.The one in my 65 was bent real bad.Someone tried to pull the rod out of the master with it in the car.I actually bent it back in the car.I was younger then and working under the dash wasnt bad.Rocky
Chrysler Firepower
Re: Brake light switch issue [Re: jburt] #1606174
04/13/14 03:21 PM
04/13/14 03:21 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
69 Charger auto with manual brakes.
Re: Brake light switch issue [Re: Prodart440] #1606175
04/13/14 03:22 PM
04/13/14 03:22 PM
N
N
Nudder view
Re: Brake light switch issue [Re: NITROUSN] #1606176
04/13/14 05:29 PM
04/13/14 05:29 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Nudder view
NITROUSN, I am correct in saying your switch makes contact with the plate/bracket in the pic, and not the pushrod or pedal arm?
Re: Brake light switch issue [Re: moparfan53] #1606177
04/13/14 06:38 PM
04/13/14 06:38 PM
N
N
Nudder view
Thats an illusion. The pedal is hanging low in the picture. The switch does hit the rod end.
Re: Brake light switch issue [Re: NITROUSN] #1606178
04/13/14 06:47 PM
04/13/14 06:47 PM
Avondale AZ
Avondale AZ
Nudder view
So here is what I did to fix it. Thanks first to the pictures in the thread, they helped a lot.
The bracket was bent. So after fighting to get it out I fought to bend it back. After bending it back I noticed in the pictures that it is bolted to the car with the top two holes, and mine was bolted using the bottom two. I bolted it up like the pictures and it works perfectly!!
Aaron
68 Coronet 440
Re: Brake light switch issue [Re: NITROUSN] #1606179
04/13/14 07:20 PM
04/13/14 07:20 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Nudder view
OK, thanks for clarifying.
