Brake light switch issue
#1606160
04/12/14 01:50 AM
04/12/14 01:50 AM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
So I have had my car apart since 2009. I am putting it together and ran across an issue with the brake light switch. I never took the pedals out, and only replaced the master cylinder. Now the brake light switch is too far to the drivers side, and slightly too high. It is hard to tell from the picture, but it is about the bolt head length away. What am I missing?? Is the bolt in backwards?? Any help is appreciated!!! Thanks!!!
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: Brake light switch issue
[Re: Prodart440]
#1606163
04/12/14 12:27 PM
04/12/14 12:27 PM
RapidRobert
You want the white round plastic head on the switch plunger to be way over to the pass side so it contacts the pedal arm not the MC pushrod or the bolt head. As said pull the wires/remove the switch/bracket & bend it flat & mock it back up. It sure seems like it is way off (but as we know pic perspective does lie) which I ain't grasping how that happened since you never moved/unbolted the mini screw but only undid the big bolt/nut to replace the MC
[Re: TJP]
#1606166
04/12/14 01:37 PM
04/12/14 01:37 PM
Prodart440
Avondale AZ
68 road runner automatic. The push rod is coming out straight. Is there supposed to be a spacer???
Aaron
[Re: Prodart440]
#1606167
04/12/14 08:32 PM
04/12/14 08:32 PM
Posts: 15,445 Omaha Ne
TJP
Omaha Ne
Just crawled up underneath the dash of my 68 Charger (in limited door opening space) OUCH!!!! you owe me, LOL Does not Appear to be a spacer. The switch is actuated by the back side/ top angle of the pushrod. Hope that makes sense. So it would appear that your switch as pictured needs to go towards the right or passenger side of the vehicle. is the bracket slotted left to right for the switch position ??? hope this helps a bit
[Re: jburt]
#1606171
04/13/14 02:26 AM
04/13/14 02:26 AM
Prodart440
Avondale AZ
So I took my bracket off. It looks nothing like the above picture of the 68 Charger. The bracket is bent, so now I am looking through my pile of parts to see if I have another one. Thanks for all the help!!!!
Aaron
[Re: Prodart440]
#1606172
04/13/14 11:56 AM
04/13/14 11:56 AM
RapidRobert
post (with a pic if you can) how it turns out
[Re: RapidRobert]
#1606173
04/13/14 02:19 PM
04/13/14 02:19 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Easy fix.Just take the switch out put the bracket in a vice and bend it some.Ive seen them bent worse than that.The one in my 65 was bent real bad.Someone tried to pull the rod out of the master with it in the car.I actually bent it back in the car.I was younger then and working under the dash wasnt bad.Rocky
Chrysler Firepower
[Re: NITROUSN]
#1606176
04/13/14 05:29 PM
04/13/14 05:29 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
Nudder view
NITROUSN, I am correct in saying your switch makes contact with the plate/bracket in the pic, and not the pushrod or pedal arm?
[Re: moparfan53]
#1606177
04/13/14 06:38 PM
04/13/14 06:38 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Nudder view
Thats an illusion. The pedal is hanging low in the picture. The switch does hit the rod end.
[Re: NITROUSN]
#1606179
04/13/14 07:20 PM
04/13/14 07:20 PM
moparfan53
NB, Canada
Nudder view
OK, thanks for clarifying.
